How to enable Intel Quick Sync Video (IQS) in DVDFab
This is a sticky topic.
    No Quicksync on 4770k
    Hello,
    I used DVDFab with Windows7 and my CPU and my NVidia without Problems. Now i switched to Windows 8.1 Pro with Mediacenter with a R9 290x from AMD. I installed DVDFab again and startet to activate my integrated GPU, hooked the Intel to a monitor but no quicksync in DVDFab. I even set the Intel as main GPU, did not work. I used the mediaSDK Analyzer, but it crashed.
    Check the screenshots.
    Has anyone a guess how to fix this?
      The latest driver version 3907 is released at 2014.08.29, maybe does not support in DVDFab. Please roll back to the old driver 3621.
      We will check and fix ASAP!
        Thanks,
        The old driver is working.
          Driver version 3907 is supported in V9167 Beta.
            Used to work, but no longer
            In older versions (before 9) I was able to enable IQS using Virtu on my ASUS P8Z68 V-Pro motherboard with an Intel 2600K i7 CPU and a AMD Radeon HD 6800 graphics card, but it no longer works. If I have Virtu enabled, DVDFab will not even load. If I disable Virtu, DVDFab loads fine, but DVDFab obviously does not detect the Intel graphics card then. Any idea on what can be done to fix this? I checked for the logs, but there isn't even a log directory on my PC.
              geezman
              What version of DVDFab do you have installed?
                geezman
                The latest version (9.1.7.1) of DVDFab
                Intel Drivers (9.17.10.3347)
                AMD Radeon Drivers (14.301.1001.0)
                  Please update Intel driver to the latest version 3907 first.
                  And I recommend that you connect Intel card to the monitor, or connect both Intel or AMD cards to the same monitor.
                  To enable IQS GPU, Intel card need to connect the monitor.
                    Wison, is the latest driver 3958 support IQS?
                      It will be supported in next new version. Please keep DVDFab up to date.
