OpenGL error
    Windows 10 LTSB x86 Working
    I have Windows 10 LTSB x86 and this works for me. Thx!
      Fix for Vista worked
      Unziped the file and copied *.dll to my Dvdfab9 folder and v9.3.0.3 now works.
        Hi all,
        - Fixed the OpenGL problem.
        - Fixed the problem that DVDFab failed to convert on Windows Vista.
        Please install the new test version and tell me the result. Thanks.
        ****Not need to copy the opengl32sw.dll to DVDFab 9 installation any more.
        Please tell me the details for your problem if you still have the problem. please also post the new DVDFab qt internal log file here (please run Qt log from DVDFab installation, see the attached screenshot).
          Hi all,
          I'm using Vista on a 32-bit PC and the new fix did not work for me.
          Also when I clicked on the "QTLog" in my DVDFab folder, it did nothing. Am I missing something?
            did you try restarting your computer ??
            and make sure that you are running dvdfab "as administrator".
              I restarted my computer and opened DVDFab as an administrator and still no success.
              I also tried running the QT Log as an administrator and nothing happened.
              For 2 years I've never experienced any major problems with DVDFab until this last update. If we can't come up with a fix--would it be possible to go back to an older version?
                DVDFab9303_2016_06_12_17_21_56.exe does also not help on my Windows 7 64bit machine. Crashes when I try to switch between FULL DISK and MAIN MOVIE.
                  Hi all,
                  When testing this, is it necessary to remove "opengl32sw.dll" from the installation folder? Or, does it matter?
                    Ultimate answer
                    The answer to this problem may be going back to the 9.2.4.4 version programming code and leaving the xp support in for now, as a couple others have suggested. The next version will tell hopefully.
                      Do you know how to roll back to the 9.2.4.4 version?
                        see here - http://forum.dvdfab.cn/showthread.php?t=29453
                          Worked on my older windows 7 64bit Acer.... Thank You!
                            did not work for me vista 32, 9244 is working fine 9303 message "work 1 failed error=filter external fabcore is exit"
                              The needed log is named dvdfab_internal.log. You can edit it with Notepad to supply only the log session related to the failure.
                                It seems as if "opengl32sw.dll" is still needed in the installation folder. I posed the question in an above post. I just updated to v9.3.0.4 and w/o this DLL it did not work.
