Chapter points change to mis-match
    By several tests, I noticed post #15 (& #16) are my mis-recognization.
    Wrong PreCommand of SetSTN is not depending on whether with-menu or no-menu. It is depending on other thing.
    to administrator
    I hope to be deleted post #15 & #16 or add above comment. I don't want to remain wrong information. But I can't edit nor delete these posts.
    Regards.
      I tested new ver.9.2.2.6.
      One of below 4 problems was fixed.
      It wa fixed about "mismatch of audio and video. No sound in first 1 minute, in this case."
      Thanks very much.
      Other 3 problems were not fixe yet. I hope to be also fixed.
      All 4 problem.
      * 1 chapter is splitted to many small cells.
      * 1 chapter becomes to 2 chapters. (this is only title 14)
      * mismatch of audio and video. No sound in first part in some case.
      * wrong PreCommand "(SetSTN) Set Audio track = 15:not set".
      Regards.
        Bug report update, I tryed ver.9.2.3.2beta.
        BD which I tested is "BEATLES 1".
        It mainly has 14 titles which involves 27 songs, where each title has 1-6 songs.
        (It is shown in left of figure of post#1.)
        I've ever tested with using all 14 titles in ver.9.2.1.6beta and 9.2.2.1beta, and now ver.9.2.3.2beta.
        I tested other vesions with using only title_14, because I've thought it has all problems.
        (1) Chapter points change to mis-match (5 titles which are 5-10 minites. details are in post#1)
        ===>This was fixed in 9.2.2.1.
        _______I've ever mis-recognized not to be fixed by below (2).
        (2) 1 chapter becomes to 2 chapters. (this is only title_14)
        ===>This was after 9.2.2.1 along with (1) fixed , so no problem in 9.2.1.6.
        _______It is different from (1). 2nd chapter is dummy chapter.
        _______All titles have initially dummy chapter. All of them are convined to each previous song except for output of ttle_14.
        (3) 1 chapter is splitted to many small cells.
        ===>This became worse to expanding to all 14 titles after 9.2.2.1 along with (1) fixed. Only 2 titles in 9.2.1.6.
        _______1 chapter of each title is devided to many cells of 15 seconds.
        (4) mismatch of audio and video. No sound in first part in some case.
        ===>This was fixed in 9.2.2.5 about titles of 1 song, but not fixed about titles of multiple songs.
        _______(I cofirmed title 14 in 9.2.2.5, and naw all titles in 9.2.3.2.)
        (5) wrong PreCommand "(SetSTN) Set Audio track = 15:not set".
        ===>This is not fixed, and now found what it depends on by (6).
        _______It depends on which audio is selected, and there is no problem when selecting DTS.
        _______(This disc has 3 audios (PCM/DTS/AC-3),and Fab initially selects DTS.
        ________I couldn't notice because DTS selecting causes error.)
        (0)When selecting DTS, Fab stops to work by error;
        (I found this bug before, but I didn't post it because DVD doesn't support DTS and Fab will covert to AC-3.)
        ===>It was fixed in ver.9.2.3.2beta.
        Regards.
