Your Next Blu-ray
    The developers have this disc now so that they can sort it out, sorry for the problem.
    //////UPDATE/////
    This was corrected in v9.1.2.6 Beta, please try it and post your results. If it still does not work for you, please post a log file session from v9.1.2.6 Beta.
      Originally posted by Ken429 View Post
      I am getting the same "black screen" as posted above. I'm using the latest version of Blu-Ray Copy and an OPPO BDP-103 to play the disc. I also get the same problem on an old Sony Blu-Ray player. I did try making a backup of just the movie and that seemed to get rid of the black screen although the movie did jump around one-time midway through but then played to the end OK as best as I could tell. Good to see that a few other people are have a similar problem with this movie. Hopefully, DVDFab will figure out what is going wrong.
      Even when I tried with DVDFab version 9.1.2.5. I still had the same result. You can try the new version 9.1.2.6. Beta as mentioned above, or you can just do the movie by itself. The correct main movie is #570. I used #570 and watched the movie all the way through and it was perfect.
        I got the same problem with Hacksaw ridge after doing a bluray copy. so is this fixed movie by movie or is there anything that dvdfab can do about?
          Server issue, it will be fixed.
