Advanced adjustments
    Where are the Advanced adjustments when you convert a file with the DVDFab 10?
    Hi paslode
    It depends on the module you are using in video converter it is here, see pic
    CBR929
      Thanks a lot for your fast answer. I reduced the width of the column title, after time, codec video, audio, subtile cannot be reduced and the icon you show in the pic are not available.
        Arrive at the end to the Arrow to view the file but still impossible to reduce the subtitle column
          Hi paslode
          Have you tried dragging the grey slider to see if you can get the advanced options back??? see pic
            Yes I do. I remove the program from the computer and reinstall it.
            If I stay on test version everything is perfect.
            If I introduce my login and password, still the same problem, the latest icons don't appear.
            New for this version, because I've already convert files last week and didn't meet this problem. The last version was installed on my computer as an upgrade.
            Hope those informations will help you
              Convert mkv to apple tv 3, but still the same for the others
                All the modules are reset to "never used"
                  paslode If you need any version of Fab that was working for you feel free to pm me with your e-mail address and I will send it to you. I can not duplicate this on my computer.
                  CBR929
                  Did you activate Fab on install? Also install Fab as administrator.
                  What version of Fab are you using? I'm installing 10015 now to see if this changes.
                  10015 is still working for me
                    Using last version 10015, found the problem, if you are on converter, click on an other option example copy and return to convert, the icons are there!!!!
                    Little bug to be corrected, for the rest super
                      Glad it's working for you must be a bug.
                      CBR929
                        Confirmed, it works
