Title Order Change Missing in Version 9?
    I have version 9.3.1.8. Using the Task Queue (button top right of your screenshot) I can change the order in which the titles are ripped. Does that not do what you want?
      Hello,
      This problem still persists in version 9.3.2.1 and 10.0.1.7, albeit the problem is slightly different between 9 and 10.
      In version 9, the same problem that kevinfritz described is not fixed. There's no way to drag or otherwise move a title from the "other" section up to the main section to resort the titles.
      In version 10, you can now see all titles in one screen, but there's no way to resort them. Drag and drop doesn't work in version 10 like it did in version 9. The program forces the order to default to longest run time first, and so on.
      For TV shows or any Blu-ray where there's more than one title that needs to be copied, this makes it impossible to sort the titles accurately.
        It will be added back in the future version.
          This has been improved in v10.0.2.1, please try it.
