durrells in corfu s1
    same issues with Poldark Season 2 (PBS / ITV)
    disk 1 and 3 are fine
    disk 2 has same problems as Durrells
      any progress?
        Originally posted by dow View Post
        any progress?
        You try the latest version 10.0.1.9 - http://forum.dvdfab.cn/showthread.php?t=30402
          No, the pixelation problem is fixed, but the menu problem is not yet.
            have you made any headway?
              any progress?
                Any progress?
                  Still could not work in the latest DVDFab?
                    10.0.42 would not load
                    10.0.0.41
                    disk 1 works
                    disk 2 skips first chapter (chap 4)
                      The above is still a issue with Poldark season 2. Each disk has 3 episodes and episode 2 uses a screenpass type protection scheme. there's a bunch of junk files in the JAR dir.
                      With that said, it has a valid playlist and if one copies it into the appropriate playlists, everything just works, but its a manual affair.
