How to enable Intel Quick Sync Video (IQS) in DVDFab
This is a sticky topic.
    Originally posted by 4Bubert View Post
    I updated to 9.1.4.0 quick sync still not working on my atom z3740 t100ta
    Please post the DVDFab internal log file and fab check log file here.
    And give us the screenshot of mediasdk info. You have post it before, did you have update the driver later?
      Info
      here is the logs and screenshot of the mediasdk
        Thank You Wilson Wang
        Heres the results
          What leads you to believe that it is not working? All indications are that it is working.
            Wilson helped me fix it. I was showing him the results. He sent me a file fixing the issue.
              Well that's wonderful for you but it doesn't help anyone else that might be having the same issue.
                for a moderator you sure aren't very kind. replacing a file with one that Wilson provided fixed my issue and it's not my place to share the file that was given to me. Wilson Wang can chime in on how he fixed it
                  It wasn't meant to be unkind but this is a forum where users like us help each other and secret fixes seems to be counter to the intent.
                    my apologies. I'm all for helping others. the device I'm using is the Asus T100TA with Atom z3740 processor for those with the same or similar device. I'm surprised intel included quicksync on a atom processor. the process that got it working is replacing the fabcheck with one provided by wilson
                      Maybe I need it too, I have a laptop with a Celeron 877 processor with the Intel HD graphics that does absolutely nothing for encode speed. It shows to be working but the encode FPS is the same with or without it. It's too slow to use for encoding anyway just a mystery.
                        I'll share my info this evening when I do some encoding
                          here's the quicksync in action and the cpu utilization. I am encoding the hunger games bluray that I own into 1080P MP4 file for ipad mini with retina
                          all this on a atom processor wow.
                            Seems like the Celeron 877 does not support IQS.
                            I seent him one file that just fix the issue which dvdfab could not detect IQS with atom CPU. And not sure the issue can be fixed.
                              It does but only decoding, they pulled encoding for the ultra low voltage processor. I did a little research and the system analyzer proved it. So I'll just use it for what it is an oversized netbook with a touchscreen.
                                4Bubert that is pretty swift! Glad you got it sorted. I recommend you check out the VidOn.Me app, I use it on my iPad and make mkv ac3 files to watch on it. I don't have the A/V sync issues that used to plague mp4 aac files. You can remux the subtitles and turn them on and off. It is far superior to the native video player and best of all it's free!
                                Here is a LINK
