Program will not open fatal error
    Originally posted by islandwx View Post
    I am having the same issue with no resolution.
    when starting media player 3.1.0.0, the error dialog box opens with a message xdisc.dll wont load.
    the file is there in the program folder and I have disabled Kaspersky, but it still wont load.
    I have version 2 installed and it works fine.
    I have uninstalled 3.1.0.0 and updated via the working ver 2, then disabled kaspersky before install and launch, but still same issue with xdisc.dll?
    Please advise?
    Make sure your chipset drivers are up to date that was my problem or make sure they are even installed.
      intel
      Unbelievable! I downloaded the Intel Driver Update Utility and ran the scan; I expected to see a chipset update! No! Only a graphics driver update.
      After installing and a reboot, the Media Player 3.1.0.0 worked fine!
      Seems odd to me?
        Seems odd to me?
        It is working Don't worry about it good news problem solved.
          Glad to it works now.
