[QUOTE=sarbare78;65381]Hi all First let me say I hope everyone had a good and filled thanksgiving. I'm not the best comp person so bare with me. I am tring to burn going the distance but it says I don't have enough space on the disc. I am burning it on a Verbatim (thanks maineman I love them)DVD+R 4.7GB 16x 120 min The movie show its a 103 min. I also tried burning it from the main movie and it still shows not enough do you want to proceed. So I put in a Fujifil DVD+RW disc my neighbor gave to proceed and see what happens and it plays the movie up till the end and cuts off the end. So I'm not sure what to do. Do I need to buy new discs with more gb or what. Oh and Im using the DVDfab 6.2.1.8 version Here are my logs.
DVDfab internal log:
170m 30.59s: detected dvd
170m 30.87s: drive I
170m 30.87s: video dvd 0
170m 30.87s: volume label
182m 32.45s: detected dvd
182m 32.98s: drive I
182m 32.98s: video dvd 0
182m 32.98s: volume label
183m 47.89s: detected dvd
183m 48.36s: drive I
183m 48.36s: video dvd 0
183m 48.36s: volume label
184m 25.20s: detected dvd
184m 25.73s: drive I
184m 25.73s: video dvd 0
184m 25.73s: volume label
DVDfab burn imgburn.log:
I 18:53:52 ImgBurn Version 2.5.1.0 started!
I 18:53:52 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
I 18:53:52 Total Physical Memory: 2,031,088 KB - Available: 1,238,856 KB
I 18:53:53 Initialising SPTI...
I 18:53:53 Searching for SCSI / ATAPI devices...
I 18:53:53 -> Drive 1 - Info: HP DVD Writer 400c Bh04 (I:) (ATA)
I 18:53:53 -> Drive 2 - Info: SAMSUNG CD-ROM SC-148A B401 (J:) (ATA)
I 18:53:53 Found 1 CD-ROM and 1 DVD+RW!
I 18:53:54 Operation Started!
I 18:53:54 Building Image Tree...
I 18:53:54 Checking Directory Depth...
I 18:53:54 Calculating Totals...
I 18:53:54 Preparing Image...
I 18:53:55 Checking Path Length...
I 18:53:55 Contents: 9 Files, 2 Folders
I 18:53:55 Content Type: DVD Video
I 18:53:55 Data Type: MODE1/2048
I 18:53:55 File System(s): ISO9660, UDF (1.02)
I 18:53:55 Volume Label: GOING_THE_DISTANCE
I 18:53:55 IFO/BUP 32K Padding: Enabled
I 18:53:55 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 18:53:55 TV System: NTSC
I 18:53:55 Size: 4,966,754,304 bytes
I 18:53:55 Sectors: 2,425,173
I 18:53:55 Image Size: 4,967,366,656 bytes
I 18:53:55 Image Sectors: 2,425,472
I 18:54:00 Operation Successfully Completed! - Duration: 00:00:06
W 18:54:04 User accepted disc space warning and is attempting to overburn!
I 18:54:04 Operation Started!
I 18:54:04 Source File: -==/\/[BUILD IMAGE]\/\==-
I 18:54:04 Source File Sectors: 2,425,472 (MODE1/2048)
I 18:54:04 Source File Size: 4,967,366,656 bytes
I 18:54:04 Source File Volume Identifier: GOING_THE_DISTANCE
I 18:54:04 Source File Application Identifier: IMGBURN V2.5.1.0 - THE ULTIMATE IMAGE BURNER!
I 18:54:04 Source File Implementation Identifier: ImgBurn
I 18:54:04 Source File File System(s): ISO9660, UDF (1.02)
I 18:54:04 Destination Device: [2:0:0] HP DVD Writer 400c Bh04 (I:) (ATA)
I 18:54:04 Destination Media Type: DVD+RW (Disc ID: RITEK-004-48) (Speeds: 2.4x, 4x)
I 18:54:04 Destination Media Sectors: 2,295,104
I 18:54:04 Write Mode: DVD
I 18:54:04 Write Type: DAO
I 18:54:04 Write Speed: MAX
I 18:54:04 Link Size: Auto
I 18:54:04 Lock Volume: Yes
I 18:54:04 Test Mode: No
I 18:54:04 OPC: No
I 18:54:05 BURN-Proof: Enabled
W 18:54:09 DeviceIoControl(FSCTL_LOCK_VOLUME) Failed! - Reason: Access is denied.
W 18:54:09 DeviceIoControl(FSCTL_DISMOUNT_VOLUME) Failed! - Reason: Access is denied.
I 18:54:09 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 18:54:10 Filling Buffer... (40 MB)
I 18:54:12 Writing LeadIn...
I 18:54:16 Writing Session 1 of 1... (1 Track, LBA: 0 - 2425471)
I 18:54:16 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2425471)
W 19:08:45 Failed to Write Sectors 2295104 - 2295135 - Reason: Logical Block Address out of Range
W 19:08:45 Retrying (1 of 20)...
W 19:08:45 Retry Failed - Reason: Logical Block Address out of Range
W 19:08:45 Retrying (2 of 20)...
W 19:08:45 Retrying (3 of 20)...
W 19:08:45 Retrying (4 of 20)...
W 19:08:45 Retrying (5 of 20)...
W 19:08:45 Retrying (6 of 20)...
W 19:08:45 Retrying (7 of 20)...
W 19:08:45 Retrying (8 of 20)...
W 19:08:45 Retrying (9 of 20)...
W 19:08:46 Retry Failed - Reason: Logical Block Address out of Range
W 19:08:46 Retrying (10 of 20)...
W 19:08:46 Retrying (11 of 20)...
W 19:08:46 Retrying (12 of 20)...
W 19:08:46 Retrying (13 of 20)...
W 19:08:46 Retrying (14 of 20)...
W 19:08:46 Retrying (15 of 20)...
W 19:08:46 Retrying (16 of 20)...
W 19:08:46 Retrying (17 of 20)...
W 19:08:46 Retrying (18 of 20)...
W 19:08:46 Retrying (19 of 20)...
W 19:08:46 Retrying (20 of 20)...
W 19:24:24 Retrying (21)...
W 19:24:24 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:27 Retrying (22)...
W 19:24:27 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:28 Retrying (23)...
W 19:24:28 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:29 Retrying (24)...
W 19:24:29 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:30 Retrying (25)...
W 19:24:30 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:32 Retrying (26)...
W 19:24:32 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:37 Retrying (27)...
W 19:24:37 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:41 Retrying (28)...
W 19:24:41 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:42 Retrying (29)...
W 19:24:42 Retry Failed - Reason: Logical Block Address out of Range
W 19:24:48 Retrying (30)...
W 19:24:48 Retry Failed - Reason: Logical Block Address out of Range
E 19:24:51 Failed to Write Sectors 2295104 - 2295135 - Reason: Logical Block Address out of Range
I 19:24:51 Synchronising Cache...
I 19:25:01 Closing Session...
E 19:25:02 Failed to Write Image!
I 19:25:05 Exporting Graph Data...
I 19:25:05 Graph Data File: C:\Documents and Settings\Sarah\Application Data\ImgBurn\Graph Data Files\HP_DVD_Writer_400c_Bh04_THURSDAY-DECEMBER-02-2010_6-54_PM_RITEK-004-48_MAX.ibg
I 19:25:05 Export Successfully Completed!
E 19:25:05 Operation Failed! - Duration: 00:30:57
I 19:25:05 Average Write Rate: 2,502 KB/s (1.8x) - Maximum Write Rate: 5,600 KB/s (4.0x)
I 19:26:10 Close Request Acknowledged
I 19:26:10 Closing Down...
I 19:26:11 Shutting down SPTI...
I 19:26:11 ImgBurn closed![/QUOTE]
First of all, when it comes to using a brand of media, stick with using either Taiyo Yuden (the very best brand when it comes to Blank DVD-R 4.7GB x4 or x8) or Verbatim DVD-R 4.7GB discs. Second, your Windows XP should be at Service Pack 3 not 2. Third, you should be using DVD-R not DVD+R because with DVD-R discs, you do not need to over burn since it can hold ~6.6mb more than a DVD+R disc. Your problem is not the DVD burner drive, it's more than likely the discs your are using. The "Low Block Address out of Range" error you keep getting when using Imgburn means that there are no more sectors on the disc to write on. Use DVD-R blank media, not DVD+R and update your DVD burner drive's firmware. You can go to and look at your DVD drive model number and search to see if there is an update to your DVD drive. Also, make sure you update to the latest version of DVDFab to v8.0.5.3 Beta. Also, reset the DMA by doing the following: Click the round green icon button with a check mark at the right top corner of the DVDFab screen, open "Common Settings" window in the upper right corner of DVDFab main screen, click on "General", click on "Reset DMA". Let me know if you have any other questions. Good luck to ya.
