Internal log:
DVDFab 8.0.5.6 (2010/12/10 21:35:37)
0m 00.53s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 04.07s: detected dvd
0m 04.11s: drive E
0m 04.11s: dvd type 1
0m 04.11s: volume label DVDVOLUME
0m 05.22s: detected blu-ray
0m 05.22s: drive F
0m 05.22s: blu-ray type 1
0m 05.24s: volume label APOLLO_13_GLO_G51
0m 05.94s: root 8CC7EADE09C4CEA9_VOLUME_SET_ID:APOLLO_13_GLO_G51:APOLLO_13_GLO_G51:APOLLO_13_GLO_G51
0m 06.77s: aacs 1 bd+ 0
0m 07.47s: got discinfo
0m 07.58s: got bdmv
0m 07.58s: got agid 0
0m 07.64s: sent host cert chal
0m 07.64s: got drive cert chal
0m 07.72s: got drive key
0m 07.72s: got host key signature
0m 07.72s: verified drive signature
0m 07.72s: verified host signature
0m 07.80s: sent host signature and key point
0m 07.80s: got bus key
0m 09.98s: got volume id
0m 09.98s: got volume id mac
0m 09.98s: volume id is correct
0m 09.98s: got vid
0m 10.07s: blu-ray C8A6E3147374A27BECB5E4DD1053AEC9DE8C4380
0m 12.55s: D B04C4306
0m 12.55s: got vuk
0m 12.60s: got unit key 7
0m 22.66s: got extended bdinfo
1m 56.44s:
1m 56.44s: create config(5)
1m 56.44s: convert profile(mkv.remux)
1m 56.44s: blu-ray playlist(0) angle(0) chapter(1->21)
1m 56.44s: stream(4113,AVC,0) stream(4352,DTS-HD MA,0) stream(4359,AC3,0) stream(4360,AC3,0) stream(4608,PGS,8) stream(4625,PGS,8) stream(4629,PGS,8) stream(4633,PGS,8)
1m 56.44s: subpicture preset(2), mode(2)
1m 56.45s: processing source(00010.m2ts)
1m 56.45s: subpicture(4608) mode(2)
32m 39.26s: error: process exception, filter(type128:id12), info = 503.00 13,
33m 40.63s: ------ mobile work failed(504.00 0 error: process exception, filter(type128:id12), info = 503.00 13,
35m 04.23s:
35m 04.23s: create config(5)
35m 04.23s: convert profile(mkv.remux)
35m 04.23s: blu-ray playlist(0) angle(0) chapter(1->21)
35m 04.23s: stream(4113,AVC,0) stream(4352,DTS-HD MA,0) stream(4359,AC3,0) stream(4360,AC3,0) stream(4608,PGS,8) stream(4625,PGS,8) stream(4629,PGS,8) stream(4633,PGS,8)
35m 04.23s: subpicture preset(2), mode(2)
35m 04.25s: processing source(00010.m2ts)
35m 04.25s: subpicture(4608) mode(2)
45m 18.19s: error: process exception, filter(type256:id11), info = 503.00 13,
45m 32.38s: ------ mobile work failed(504.00 0 error: process exception, filter(type256:id11), info = 503.00 13,
53m 09.37s:
53m 09.37s: create config(5)
53m 09.37s: convert profile(mkv.remux)
53m 09.37s: blu-ray playlist(0) angle(0) chapter(1->21)
53m 09.37s: stream(4113,AVC,0) stream(4352,DTS-HD MA,0) stream(4359,AC3,0) stream(4360,AC3,0) stream(4608,PGS,8) stream(4625,PGS,8) stream(4629,PGS,8) stream(4633,PGS,8)
53m 09.37s: subpicture preset(2), mode(2)
53m 09.39s: processing source(00010.m2ts)
53m 09.39s: subpicture(4608) mode(2)
80m 05.61s: error: process exception, filter(type128:id12), info = 503.00 13,
81m 00.50s: ------ mobile work failed(504.00 0 error: process exception, filter(type128:id12), info = 503.00 13,
I'm using Windows 7 64-bit.
