[QUOTE=LionisBad;77239]DVDFab 8.0.6.1 (2011/02/20 13:14:28)
0m 00.78s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
3m 03.06s: detected blu-ray
3m 03.06s: drive E
3m 03.06s: blu-ray type 1
3m 03.06s: volume label KILLERS
DVDFab 8.0.6.1 (2011/02/20 13:17:35)
0m 00.82s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
0m 06.30s: detected blu-ray
0m 06.31s: drive E
0m 06.31s: blu-ray type 1
0m 06.31s: volume label KILLERS
0m 12.83s: root 8CCF32E160A6B393_VOLUME_SET_ID:KILLERS:KILLERS:KILLERS
0m 28.95s: detected blu-ray
0m 28.95s: iso C:\Users\Jamal\Desktop\New folder\KILLERS.ISO
0m 28.95s: blu-ray type 1
0m 28.95s: volume label KILLERS
0m 31.18s: root 8CCF32E160A6B393_VOLUME_SET_ID:KILLERS:KILLERS:KILLERS
0m 31.20s: aacs 0 bd+ 0
0m 32.82s: got discinfo
0m 32.82s: got bdmv
0m 34.07s: stream(2,3,0)/clip(2,3,6) infos are not the same, using clip info to regulate it.
0m 34.50s: got extended bdinfo
4m 01.63s: Blu-ray Copy: Main Movie
4m 01.63s: Source: [:\BDMV\
4m 01.63s: Playlist: 637
4m 01.63s: Chapters: 1 -> 17
4m 01.63s: SourceSize: 30591 MB
4m 01.63s: RemoveHDAudio: 0
4m 01.63s: OutputTarget: BD25
4m 01.63s: OutputVideo: 1080p/i
4m 01.66s: Video reencode bitrate (25877 kbps)
4m 01.66s: compress begin: Blu-ray groups clips(00626.m2ts), playtime(6023851 ms), size(31146 MB)
4m 01.67s: processing source(00626.m2ts)
4m 01.67s: Lightning-Recoding (accelerate H.264 software decoding and encoding) enabled
4m 02.76s: h264_encode: encode param profile(2) level(41) bitrate(25877)
157m 53.06s: group(00626.m2ts ) playtime(6023851 ms) source(31146 MB) request(23463 MB) real(22603 MB) bitrate(25877 kbps)
157m 53.11s: compress finished: groups request(23463 MB, 23463 MB) real(22603 MB) average_bitrate(25877 kbps)[/QUOTE]
I hope one of the senior members can take a look at this!! first thing you are using a very old version of Fab .7.3 is the latest build with a new beta out! Also it looks like the movie you are copying does not have any BD protection? Are you using the original disc? Also I have never seen this "0m 34.07s: stream(2,3,0)/clip(2,3,6) infos are not the same, using clip info to regulate it." But it could have something to do with burning and ISO, which I never do! Can you post a screen shot of the Fab screen when you have everything selected that you want? Using the snipping tool that comes with win 7 if thats what you are using?
