WooHoo thanks to whomever figured out the whole chapter 10 thing. It worked PERFECTLY.... Thanks again.So to all the people coming in for answers, currently that is the best suggestion.
What i did.
1.downloaded the newest system
2.turned off pathfinder
3.went into customize part, and selected chapter 10
And there you go, it was done in less than an hour. It worked perfectly with no errors, no lags, no freezing. It was good.
