Hi, Newbie here. When compression has to occur (fitting a larger movie file to a 25GB disc), does the software remove all HD Audio from the whole movie, or just some where needed? based on how much is needed? In general, about how much GB of space is devoted to HD audio as compared to regulare Dolby Digital or DTS? If after deleting the HD audio, there is still not room, then does the software start lowering resolution? And, again, across the whole disc or where needed to make it fit? Thanks!
