Man, what a Sunday!
So I've been playing with getting a DVD to rip into an MP4/h264/aac file this weekend with the latest version of DVDFab so it'll play in my Xbox360. To make a looooong story short, the 360 apparently does NOT like variable frame rate videos.
Just to test this, I wrangled two sample files: one that MediaInfo reports as "Constant" frame rate mode (from old rips I had done) and the other is "Variable" frame rate mode. The variable will not play in the Xbox while the constant will.
I did a lot of searching and found older forums posts talking about how recent DVDFab versions are all using VFR now.
So the question is: How can we adjust which frame rate mode is used?
P.S. Just for reference, here's the video bits from the two files:
== Video 1 (works in XBox)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2mn 33s
Bit rate mode : Variable
Bit rate : 4 086 Kbps
Maximum bit rate : 6 000 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.592
Stream size : 74.6 MiB (97%)
== Video 2 (does NOT work in XBox)
Video
Format : AVC
Codec ID : avc1
Duration : 11mn 52s
Bit rate : 4 126 Kbps
Maximum bit rate : 6 144 Kbps
Width : 720 pixels
Height : 306 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Variable
Minimum frame rate : 23.974 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.781
Stream size : 351 MiB (97%)
Encoded date : UTC 2012-10-28 23:21:00
Tagged date : UTC 2012-10-28 23:22:44
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
