Supernatural Season 1, disc 1. It's a very large file (over 4 hours) thanks to the way it was authored. All episodes are in a single file.
The audio gets out of sync over time, lagging six or seven seconds by the end.
Ripping to mkv.h264.ac3, tried with both hardware and software only. Searched the forums and found a similar thread, but no resolution.
This is the first Blu Ray that gives me this problem. I have ripped my entire movie collection and some TV shows with no issues.
Windows 7 x64, 12GB memory, Intel i7 950, GTX 470.
22m 45.17s: info: create config(5)
22m 45.17s: info: convert profile(mkv.h264.ac3)
22m 45.17s: info: bluray playlist(100),angle(0),chapter(1->42),3D(0)
22m 45.18s: info: streams((4113.2)(4352.2))
22m 45.18s: info: set output video frame_rate(24000/1001)
22m 45.18s: source audio(86019,6,0,48000) is the same as output audio(bitrate 640000), passthrough it
22m 45.19s: info: enable multi-thread software decoder
22m 46.21s: info: h264_encode: encode param profile(2) level(41) bitrate(7458)
22m 50.24s: info: processing source(00034.m2ts)
53m 59.95s: info: processing source(00035.m2ts)
83m 26.85s: info: processing source(00036.m2ts)
113m 39.35s: info: processing source(00037.m2ts)
142m 47.61s: info: processing source(00038.m2ts)
171m 55.65s: info: processing source(00039.m2ts)
201m 35.88s:
