[QUOTE=snafu;156175]Start Task manager, open the Processes tab. Start DVDFab 9122. Start your copy to your hard drive. Your CPU is almost pegged at 95-99%, right?
I have the same problem with any DVD on Version 9119 & 9122. If I start the copy then minimize the program so it's just an icon in the system tray it works great, in fact you can hear the read drive speed up!
Look at the task manager, it has dropped to less than 20%, right? Maximize the DVD Fab for just a second and you'll see that drive speed is way up and the CPU % will spike until you minimize DVD Fab again.
It didn't work as quite well for me, but a very helpful moderator, signals, had me do this:
1) Start ver. 9122, but don't start your copy.
2) Go to the top right corner and click on the little upside down triangle, from the drop down list select Common Settings
3) Click on Drives, then Read, then un-check the Enable read-ahead cache box.
That will help, You can also look above that where it says I/O Mode & change from auto to SPTI.
Or, we People with inferior computers can just minimize ver. 9.1.2.2. once it starts to copy.[/QUOTE]
Thanks for your input here, and your other message to me .I used 8230 and it worked perfectly .
I will keep the information from you when I encounter another Version 9 problem.But like you said I probably need a better stand alone graphics card to max my processing speed.
