Same problem
...but my output is MKV, audiocopy, not AAC.
And it seems most of the movies I did rip from blu-ray has this issue... From a very long time.
my log :
DVDFab 9.1.4.6 (2014/05/22 23:17:09)
0m 00.96s: Init Public log : enabled.
0m 00.96s: Init Private log : finish.
0m 00.96s: App info: 2014-5-22
0m 00.96s: App info: 9.1.4.6 9146 Official
0m 01.26s: Init CrashReportSettings : enabled.
0m 01.26s: Init DVDInfo_Log : enabled.
0m 01.26s: Init Qt_Log : disabled.
0m 04.10s: Profile Manager :: Begin Load Profile
0m 04.36s: Qt Translator file load success
0m 04.43s: App info: client type 2.
0m 04.44s: Fabplay load: preload successful.
0m 04.49s: Fabplay load: Load successful.
0m 04.49s: Init process: Transfer settings successful.
0m 04.49s: info: fabcheck logpath= C:/Users/Chris/Documents/DVDFab9/Log/
0m 05.25s: info: fab_check_gpu is running ...
0m 15.26s: info: fab_check_gpu run out of time , terminating
0m 15.26s: info: recommand= 0, Shrink support= 0, enable= 0, cuda_cap= 0 , cpu_count= 4
0m 15.26s: GPU check: GPUAccelerate-0
0m 15.26s: GPU check: GPUAccelerate setting-0, 0
0m 15.26s: GPU check: CUDA cap-0
0m 15.26s: GPU check: Support coreavc decode-0
0m 15.26s: GPU check: Lighting shrink status-0, 0
0m 15.26s: Init process: Load config failed.
0m 15.26s: Init process: Windows os type is 64bit System Windows 7.
0m 15.26s: Init process: command line in is
0m 15.61s: Reg check: Parse string: ( 2:8260762964 )( 11:8260762964 )( 20:8260762964 )( 21:8260762964 )( 22:8260762964 )( 60:8260762964 )( 1:0 )( 50:0 )( 62:0 )( 70:0 )( OV:9146 )( BV:9143 )( S:9dfe4af537e6f8c61f11ac2afab8b9c8 )
0m 15.62s: Reg check: Option check status-Local
0m 15.62s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):0:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:0:0 )-( Blu-ray to DVD:1:1 )-( File to DVD:1:0 )-( File to Blu-ray:0:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:0:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
0m 15.62s: App info: language type FRA.
0m 15.62s: Reg check: Start get sys number.
0m 15.62s: Reg check: Serial number is: 00-ff-f9-0a-32-f1:bc-ae-c5-92-a8-7b
0m 15.62s: Reg check: Connect type is: 0
0m 15.62s: Init process: Init GPU settings successful.
0m 16.17s: Init preview: Begin init preview play engine.
0m 16.17s: Init preview: Begin init preview play engine(XBMC).
0m 16.95s: Reg check: Times of connecting error is: 0
0m 16.95s: Reg check: Parse string: ( S:5259bf1f6b2b4f6d387d71594948f586
0m 17.39s: Reg check: Option check status-NewWork
0m 20.83s: Profile Manager :: End Load Profile
0m 23.46s: Init preview: Init internal engine successful.
0m 33.20s: Burn engine: start init.
0m 40.83s: Burn engine: engine type-0.
0m 40.83s: Burn engine: writer count 1.
0m 40.83s: Burn engine: 0- M:\ [HL-DT-ST BDDVDRW CH10LS20 1.00 (Ide)].
0m 40.83s: Burn engine: end init.
0m 41.78s: Init process: Init setting page successful.
0m 41.78s: QtLog Mode = false
0m 41.78s: Show UI Step 2
0m 42.13s: Show UI Step 3
0m 42.13s: Start show MainUI.
0m 42.13s: UI manager: switch to Converter mode.
0m 44.63s: allow_test : false
0m 50.51s: Init process: init main ui successful.
0m 51.45s: Init process: show main ui successful.
0m 51.45s: DriveX msg: Init driveX M with I/O mode: 0
0m 51.64s: opening drive M
0m 51.64s: opened i/o
0m 51.65s: got media type 15
0m 54.31s: got max lba 23310047
0m 55.46s: got disc type 20
0m 55.46s: type Blu-ray BDMV
0m 55.46s: volume label Spider-Man 2
0m 55.47s: DriveX msg: add media in driveX M.
0m 55.47s: DriveX msg: send open media msg to thread for driveX M.
0m 59.75s: opening drive M
0m 59.75s: opened i/o
0m 59.75s: got media type 15
1m 00.14s: got max lba 23310047
1m 01.28s: got disc type 20
1m 01.28s: type Blu-ray BDMV
1m 01.28s: volume label Spider-Man 2
1m 01.28s: Source manager: add source id 0.
1m 01.29s: Source open status:DVD Yes, 2231-10-11
1m 01.29s: Source open status:BD Yes, 2231-10-11
1m 01.29s: internal path M:/BDMV/
1m 01.87s: aacs 1 bd+ 0
1m 02.19s: got bdmv
1m 02.58s: movie name: spider-man 2 (2004)
1m 02.58s: got agid 0
1m 02.60s: sent host cert chal
1m 02.60s: got drive cert chal
1m 02.60s: BEC 0
1m 02.60s: DRIVE_VENDOR 0x0116
1m 02.64s: got drive key
1m 02.64s: got host key signature
1m 02.64s: verified drive signature
1m 02.64s: verified host signature
1m 02.67s: sent host signature and key point
1m 02.67s: got bus key
1m 02.67s: got volume id
1m 02.67s: got volume id mac
1m 02.67s: volume id is correct
1m 02.67s: got vid
1m 02.79s: blu-ray F5B8DE7E0DAB6DAD99EA3C13F3051F53CAD4F8ED
1m 03.30s: cert BEE=0x00 same
1m 08.18s: D 1D283E17
1m 08.18s: main playlist 00002.mpls
1m 08.18s: selected region B
1m 08.18s: got vuk
1m 08.19s: got unit key 4
1m 28.62s: got bdmv
1m 49.06s: got extended bdinfo
1m 49.06s: opened blu-ray
1m 49.41s: Source manager: open successful.
1m 49.93s: Work manager: create Converter work 0 with source 0 and uiinfo 0( title 2 ).
1m 53.58s: ========WorkAttr::SetSource=======
1m 53.58s: Source Video Size Original : 1920 x 800
1m 53.58s: Source Video Size Display : 1920 x 800
1m 53.58s: Source Video FPS : 24000 / 1001
1m 53.58s: Source Video Bitrate : 1200
1m 53.59s: Source Audio Bitrate : 0
1m 53.59s: Source Audio Channels : 6
1m 53.59s: Source Audio Volume : 100
1m 53.59s: Work Profile : MKV.Default
2m 00.18s: Work manager: create Converter work 1 with source 0 and uiinfo 0( title 1 ).
2m 05.74s: ========WorkAttr::SetSource=======
2m 05.74s: Source Video Size Original : 1920 x 800
2m 05.74s: Source Video Size Display : 1920 x 800
2m 05.74s: Source Video FPS : 24000 / 1001
2m 05.74s: Source Video Bitrate : 1200
2m 05.74s: Source Audio Bitrate : 0
2m 05.74s: Source Audio Channels : 6
2m 05.74s: Source Audio Volume : 100
2m 05.74s: Work Profile : MKV.Default
2m 50.76s: UILog:OnMsgToolbar_Start
2m 50.77s: UILog:Msg Start : ready start
2m 50.77s: UILog:Msg Start : start test run work
2m 50.77s: UILog:right button to null, work falg = -1
2m 50.78s: UILog:Msg Start : run work
2m 50.78s: UILog:Run current Work.
2m 50.78s: UILog:Begin work Converter.
2m 50.78s: UILog:Begin work copy or converter.
2m 50.78s: Start check Blu-ray Ripper (3D Plus) register status.
2m 50.78s: End check Blu-ray Ripper (3D Plus) register status: Enable
2m 50.78s: UILog:start running at thread.
2m 50.78s: UILog:return flag at start running at thread ok.
2m 50.81s: OPList at BD Converter : (4113.2),(4352.1),(4358.1),(4608.16),(4609.16),(4614.16),(4619.16),(4621.16)
2m 50.81s: Blu-ray Converter (3D Plus) check watermark flag: 0
2m 50.81s: ------------------ convert work begin(1/1) ------------------
2m 50.81s: start fab process
2m 50.82s: info: create config(bluray2video)
2m 50.82s: info: use profile(MKV.Default)
2m 50.82s: info: bluray playlist(1),angle(0),chapter(1->52),BDAV(no)
2m 50.82s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
2m 50.85s: info: stream input@ Video(4113)[codec(h264) size(1920*1080) fps(24000/1001) interlace(0) duration(0)sec opcode(compress)]
2m 50.96s: info: perset file config OK !
2m 50.96s: info: set output video frame_rate(24000/1001)
2m 50.96s: info: stream output Video(4113)[codec(h264) size(1920*800) fps(24000/1001) interlace(0) bitrate(9207) duration(0)sec]
2m 50.97s: info: stream input@ Audio(4352)[codec(dca) channels(6) sample(48000) bitrate(0) bitdepth(16) opcode(copy)]
2m 50.97s: info: stream output Audio(4352)[codec(dca) channels(6) sample(48000) bitrate(0) bitdepth(16) opcode(copy)]
2m 50.97s: info: stream input@ Audio(4358)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(0) opcode(copy)]
2m 50.97s: info: stream output Audio(4358)[codec(ac3) channels(6) sample(48000) bitrate(448000) bitdepth(0) opcode(copy)]
2m 50.97s: info: stream input@ SubPicture(4608)[codec(pgssub) language(English) opcode(extract)]
2m 50.97s: info: stream output SubPicture(4608)[codec(xsub) language(English)]
2m 50.97s: info: stream input@ SubPicture(4609)[codec(pgssub) language(English) opcode(extract)]
2m 50.97s: info: stream output SubPicture(4609)[codec(xsub) language(English)]
2m 50.97s: info: stream input@ SubPicture(4614)[codec(pgssub) language(French) opcode(extract)]
2m 50.97s: info: stream output SubPicture(4614)[codec(xsub) language(French)]
2m 50.97s: info: stream input@ SubPicture(4619)[codec(pgssub) language(English) opcode(extract)]
2m 50.97s: info: stream output SubPicture(4619)[codec(xsub) language(English)]
2m 50.97s: info: stream input@ SubPicture(4621)[codec(pgssub) language(French) opcode(extract)]
2m 50.97s: info: stream output SubPicture(4621)[codec(xsub) language(French)]
2m 50.97s: info: stream input@ SubPicture(16781824)[codec(pgssub) language(English) opcode(extract)]
2m 50.97s: info: stream output SubPicture(16781824)[codec(xsub) language(English)]
2m 50.97s: info: stream input@ SubPicture(16781825)[codec(pgssub) language(English) opcode(extract)]
2m 50.97s: info: stream output SubPicture(16781825)[codec(xsub) language(English)]
2m 50.98s: info: stream input@ SubPicture(16781830)[codec(pgssub) language(French) opcode(extract)]
2m 50.98s: info: stream output SubPicture(16781830)[codec(xsub) language(French)]
2m 50.98s: info: stream input@ SubPicture(16781835)[codec(pgssub) language(English) opcode(extract)]
2m 50.98s: info: stream output SubPicture(16781835)[codec(xsub) language(English)]
2m 50.98s: info: stream input@ SubPicture(16781837)[codec(pgssub) language(French) opcode(extract)]
2m 50.98s: info: stream output SubPicture(16781837)[codec(xsub) language(French)]
2m 50.98s: info: SubMode(Extract) -- Display Only forced Subtitle(true)
2m 50.98s: UILog:MsgWork:WorkStatus_Start
2m 50.99s: info: enable multi-thread software decoder, thread count = 4
2m 52.74s: info: h264_encode: encode param profile(2) level(41) bitrate(9207) crf(-1)
2m 52.76s: info: processing source(00000.m2ts)
112m 06.54s: info: processing source(00072.m2ts)
138m 36.26s: info: enable multi-thread software decoder, thread count = 4
138m 36.27s: info: h264_encode: encode param profile(2) level(41) bitrate(9207) crf(-1)
138m 43.09s: info: processing source(00000.m2ts)
142m 46.27s: info: processing source(00014.m2ts)
144m 23.26s: info: processing source(00015.m2ts)
146m 11.33s: info: processing source(00016.m2ts)
150m 56.02s: info: processing source(00017.m2ts)
152m 28.38s: info: processing source(00018.m2ts)
154m 39.99s: info: processing source(00019.m2ts)
157m 17.06s: info: processing source(00048.m2ts)
158m 10.90s: info: processing source(00049.m2ts)
158m 49.91s: info: processing source(00050.m2ts)
159m 47.92s: info: processing source(00051.m2ts)
162m 56.54s: info: processing source(00052.m2ts)
164m 05.76s: info: Find Forced Subtitle Stream : PID(4608), Language(English), First Time At(timestamp: 00:26:12:608)
166m 05.32s: info: processing source(00053.m2ts)
247m 53.12s: info: processing source(00072.m2ts)
273m 58.53s: ------------------ convert work finished ------------------
273m 59.66s: UILog:MsgWork:current work finish : 3
273m 59.66s: UILog:Run Work to end.
274m 13.59s: Exit process: stop running.
274m 13.70s: Exit process: preview pfn_releaseplayer end
274m 13.76s: Exit process: preview pfn_deinit end
274m 13.98s: Exit process: preview FreeLibrary end
