Okay, latest nVidia drivers installed and Blu-ray drive firmware updated to 1.6
AV codecs disabled (set to software) and repeated on version 9. Sadly I still get the same problem. It rips for approximately 2% and then just hangs in the rip. No drive activity, no cpu activity etc.
Latest log file:
DVDFab 9.3.2.1 (2017/04/11 22:28:52)
0m 00.03s: Init Public log : enabled.
0m 00.03s: Init Private log : finish.
0m 00.03s: App info: 2016-11-8
0m 00.03s: App info: 9.3.2.1 9321 Official
0m 00.06s: Init CrashReportSettings : enabled.
0m 00.06s: Init DVDInfo_Log : enabled.
0m 00.06s: Init Qt_Log : disabled.
0m 00.06s: --- 3D implement select : Use default implement ---
0m 00.14s: Profile Manager :: Begin Load Profile
0m 00.14s: Qt Translator file load success
0m 00.14s: App info: client type 2.
0m 00.17s: MobilePlay load: preload successful.
0m 00.21s: MobilePlay load: Load successful.
0m 00.21s: set code page : .0
0m 00.21s: Init process: Transfer settings successful.
0m 00.21s: info: check logpath= C:/Users/Iain/Documents/DVDFab9/Log/
0m 00.23s: info: _check_gpu is running ...
0m 00.56s: info: check_gpu run successful
0m 00.56s: info: recommand= 56, Shrink support= 0, enable= 0, cuda_cap= 1 , cpu_count= 6
0m 00.56s: GPU check: GPUAccelerate-0X3F
0m 00.56s: GPU check: GPUAccelerate setting-0X38, 0X38
0m 00.56s: GPU check: CUDA cap-0X1
0m 00.56s: GPU check: Support coreavc decode-0
0m 00.56s: GPU check: Lighting shrink status-0, 0
0m 00.56s: GPU check: Graphics info 1: NVIDIA Quadro 2000 : 21.21.13.7711 : 2.1
0m 00.58s: Init process: Load config successful.
0m 00.58s: Init process: Windows os type is 64bit System Windows 10 Build 14393.
0m 00.58s: Init process: command line in is
0m 00.66s: Reg check: Parse string: ( 2:8263532095 )( 11:8260762964 )( 21:8260762964 )( 22:8260762964 )( OV:9322 )( BV:9320 )( S:f378b0fcab2d829cd8599cf41199780d )
0m 00.67s: Reg check: Option check status-Local
0m 00.67s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:0 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:0 )-( Blu-ray to DVD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:0 )-
0m 00.67s: App info: language type ENU.
0m 00.67s: App info: Install path C:/Program Files (x86)/DVDFab 9/
0m 00.67s: Init process: Set account info to DriveX.
0m 00.67s: Export Blu-ray source information report : enabled
0m 00.67s: Init process: Init GPU settings successful.
0m 00.67s: connect plugin info : start.
0m 00.99s: Reg check: Times of cinavia connecting error is: 0
0m 00.99s: Reg check: Start get sys number.
0m 00.99s: Reg check: Serial number is: 1c-6f-65-ac-35-8d
0m 00.99s: Reg check: Connect type is: 0
0m 00.99s: Profile Manager :: End Load Profile
0m 01.77s: connect plugin info : 1:1
0m 02.25s: Reg check: Times of connecting error is: 0
0m 02.25s: Reg check: Parse string: ( S:018fd1dc21e2cee7feeb8a88e5299cd8
0m 02.25s: Reg check: Option check status-NewWork
0m 02.85s: Init preview: Begin init preview play engine.
0m 02.85s: Init preview: Begin init preview play engine(DirectShow).
0m 02.85s: Init preview: Init DirectShow engine successful.
0m 03.63s: Burn engine: start init.
0m 03.63s: Burn engine: set log folder.
0m 03.63s: DVD: init read settings.
0m 03.63s: DVD: init write settings.
0m 04.11s: BD: init read settings.
0m 04.11s: BD: init write settings.
0m 04.11s: bd set region B
0m 04.11s: Burn engine: config engine type-0 begin.
0m 04.11s: Burn engine: config engine type-0 end.
0m 04.11s: Burn engine: writer count 3.
0m 04.11s: Burn engine: 0- H:\ [PIONEER BD-RW BDR-207D 1.60 (Scsi)].
0m 04.11s: Burn engine: 1- I:\ [Optiarc DVD RW AD-5240S 1.02 (Scsi)].
0m 04.11s: Burn engine: 2- L:\ [Audials Tunebite CD-R 1.00 (Scsi)].
0m 04.13s: Burn engine: end init.
0m 04.81s: Init process: Init setting page successful.
0m 04.83s: QtLog Mode = false
0m 04.83s: Show ProductsInfo Dlg 2
0m 09.52s: Show UI Step 3
0m 09.52s: Start show MainUI.
0m 09.52s: UI manager: switch to Converter mode.
0m 11.28s: Init process: init main ui successful.
0m 11.88s: Init process: show main ui successful.
0m 11.88s: DriveX msg: Init driveX H with I/O mode: 0
0m 11.88s: DriveX msg: Init driveX I with I/O mode: 0
0m 11.89s: DriveX msg: Init driveX L with I/O mode: 0
0m 11.94s: opening drive H
0m 11.94s: opened i/o
0m 11.95s: got media type 15
0m 12.39s: got max lba 20951167
0m 13.16s: got disc type 20
0m 13.16s: type Blu-ray BDMV
0m 13.16s: volume label STARTREK11D1EU
0m 13.16s: DriveX msg: add media in driveX H.
0m 13.17s: DriveX msg: send open media msg to thread for driveX H.
0m 13.17s: opening drive L
0m 13.17s: opened i/o
0m 13.17s: got media type 2
0m 13.18s: got max lba 0
0m 13.18s: DriveX msg: media open(false) failed in driveX L.
0m 13.18s: Source manager:open source flag:1,1,1,1,1
0m 13.18s: opening drive I
0m 13.18s: opened i/o
0m 13.19s: Source manager:open source flag:1,1,1,1,1
0m 13.20s: Source manager: add source id 0.
0m 13.21s: bd set region ?
0m 13.21s: Source open status:DVD Yes, 2231-10-11
0m 13.21s: Source open status:BD Yes, 2231-10-11
0m 13.21s: internal path H:/BDMV/
0m 13.22s: aacs 1 bd+ 0
0m 13.80s: got bdmv
0m 13.82s: got agid 0
0m 13.90s: sent host cert chal
0m 13.91s: got drive cert chal
0m 13.91s: BEC 1
0m 13.91s: DRIVE_VENDOR 0x0067
0m 13.96s: got drive key
0m 15.15s: got host key signature
0m 15.15s: verified drive signature
0m 15.15s: verified host signature
0m 15.20s: sent host signature and key point
0m 15.20s: got bus key
0m 15.20s: got volume id
0m 15.21s: got volume id mac
0m 15.21s: volume id is correct
0m 15.21s: got vid
0m 15.48s: blu-ray 7B7EF2A61C52EF58AF9008C6B4E36F85A2750CAD
0m 15.98s: cert BEE=0x00 same
0m 16.48s: D 62B8B0F0
0m 16.48s: main playlist 00000.mpls
0m 16.49s: selected region B
0m 16.49s: bd set region B
0m 16.49s: got vuk
0m 16.69s: got unit key 7
0m 17.38s: StealthyClone with BluPath
0m 18.62s: got bdmv
0m 24.10s: got extended bdinfo
0m 24.10s: opened blu-ray
0m 24.32s: Cinavia : no cinavia repair data.
0m 25.33s: Meta : the ownership is E_Meta_Is_Not_Owner.
0m 25.33s: Source manager: open successful.
0m 25.35s: Meta : editable flag is META_INFO_EDITABLE_FLAG_NONE
0m 25.36s: Meta : Load meta info data from server.
0m 26.71s: Work manager: create Converter work 0 with source 0 and uiinfo 0( title 0 ).
0m 43.84s: ========WorkAttr::SetSource=======
0m 43.84s: Source Video Size Original : 1920 x 800
0m 43.84s: Source Video Size Display : 1920 x 800
0m 43.84s: Source Video FPS : 24000 / 1001
0m 43.84s: Source Video Bitrate : 1200
0m 43.84s: Source Audio Bitrate : 0
0m 43.84s: Source Audio Channels : 6
0m 43.84s: Source Audio Volume : 100
0m 43.84s: Work Profile : MKV
0m 44.09s: Source manager:open source flag:1,1,1,1,1
1m 06.82s: UILog:OnMsgToolbar_Start
1m 06.82s: UILog:Msg Start : ready start
1m 06.82s: UILog:Msg Start : start test run work
1m 06.83s: UILog:right button to null, work falg = -1
1m 06.90s: UILog:Msg Start : run work
1m 06.90s: UILog:Run current Work.
1m 06.90s: UILog:Begin work Converter.
1m 06.90s: UILog:Begin work copy or converter.
1m 06.90s: Start check Blu-ray Ripper register status.
1m 06.91s: End check Blu-ray Ripper register status: Enable
1m 06.91s: UILog:start running at thread.
1m 06.91s: UILog:return flag at start running at thread ok.
1m 06.94s: OPList at BD Converter : (4113.2),(4352.2),(4610.32),(4618.32),(4624.32)
1m 06.94s: Blu-ray Converter (3D Plus) check watermark flag: 0
1m 11.35s: ------------------ convert work begin(1/1) ------------------
1m 11.35s: start process(1/1)
1m 11.35s: info: create config(bluray2video)
1m 11.36s: info: crop value after clone: left = 0 right= 0 top=140 bottom=140 enable=1 mode=1
1m 11.36s: info: use profile(MKV)
1m 11.36s: info: bluray playlist(0),angle(0),chapter(1->15),BDAV(no)
1m 11.36s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
1m 11.37s: info: stream input@ Video(4113)[codec(h264) size(1920*1080) fps(24000/1001) interlace(0) duration(7610)sec opcode(compress)]
1m 11.37s: info: perset file config OK !
1m 11.37s: info: set output video frame_rate(24000/1001)
1m 11.37s: info: vdecode hevc= 0, h264= 0, vc1= 0, mpeg2= 0, vencode h264= 0, hevc= 0 , plat = 0
1m 11.37s: info: stream output Video(4113)[codec(h264) size(1920*800) fps(24000/1001) interlace(0) bitrate(3683) duration(7610)sec]
1m 11.37s: info: stream input@ Audio(4352)[codec(truehd) channels(6) sample(48000) bitrate(640000) bitdepth(24) opcode(compress)]
1m 11.38s: info: stream output Audio(4352)[codec(ac3) channels(2) sample(44100) bitrate(192000) bitdepth(16) opcode(compress)]
1m 11.38s: info: stream input@ SubPicture(4610)[codec(pgssub) language(English) opcode(remux)]
1m 11.38s: info: stream output SubPicture(4610)[codec(pgssub) language(English)]
1m 11.39s: info: stream input@ SubPicture(4618)[codec(pgssub) language(English) opcode(remux)]
1m 11.39s: info: stream output SubPicture(4618)[codec(pgssub) language(English)]
1m 11.39s: info: stream input@ SubPicture(4624)[codec(pgssub) language(English) opcode(remux)]
1m 11.39s: info: stream output SubPicture(4624)[codec(pgssub) language(English)]
1m 11.39s: info: SubMode(Remux) -- Display Only forced Subtitle(false)
1m 11.39s: UILog:MsgWork:WorkStatus_Start
1m 11.40s: info: enable multi-thread software decoder, thread count = 6
1m 11.40s: info: ex process path= C:/Program Files (x86)/DVDFab 9/fabcore.exe
1m 11.44s: info: h264_encode: encode param profile(2) level(41) bitrate(3683) crf(-1) interlace(0)
1m 11.46s: info: processing source(00000.m2ts)
