The last time I used Merge mode it did not support original disc menus and I believe this is still the case. The playable content may be there but it will not be accessible from any sort of menu, do you see a menu when you play the Merged content in VLC?
signals
No I don't. For the Merged backup of IT, I ripped each Side of the DVD using Main Movie Mode so there wouldn't be any Menus.
I may be confusing you because I included 2 issues that I believe our linked.
TV Series DVDs are handled 1 of 2 different ways when you select to "Play All Episodes".
1 way is it combines all of the episodes into 1 title. It treats the multi-episodes as 1 "movie" the "time bar" will be in the 2-3 hour range instead of 18-43 minutes.
The other way is just to link the individual episodes together and play them in sequence. The "time bar" will show the length of each episode instead of the combination of all episodes.
If I do a full dvd copy of a TV Series that is constructed in the first way, It will play properly with DVD Fab Player.
If I do a full dvd copy of a TV Series that is constructed in the second way, It will not play properly with DVD Fab Player. It only plays the 1st episode and goes back to the start menu. I can play each episode individually, but when I select play all from the DVD menu, it only plays the first menu.
I included the Merged copy of "IT" in this problem, as the construction of the Merged Title is the same as a TV Series constructed with the 2nd method.
