Problems When Installing and Using DVDFab on Mac
You may encounter a “System Extension Blocked” message when trying to install DVDFab. Additionally, you may experience issues such as DVDFab being unable to read discs or burn DVD/Blu-ray folder/ISO files to blank discs.
Not to worry, we will guide you on how to resolve these issues.
Please refer to the guides in this article for instructions on repairing it using the command line.
1. Open Terminal
2. Type sudo -s in the Terminal (note: there is a space in the middle) or simply copy sudo -s and paste.
3. Entering the password of your Mac, press Enter on the keyboard.
If you see the root user info, it indicates that the steps are correct.
4. Copy and Paste the command line below to uninstall the driver.
One command line one line. Press Enter after pasting each command line to execute it.
kextunload /Library/Extensions/fabio.kext
rm -rf /Library/Extensions.kextcache
rm -rf /Library/Extensions.mkext
kextcache -k /Library/Extensions
kextcache -system-prelinked-kernel
If you get an error while performing the uninstall driver step, it means that the driver was not installed correctly to begin with. Please ignore it and continue to the next step.
5. Install DVDFab Mac and run it, and then exit the application. This is to let the DVDFab install fabio.kext in the specified directory.
6. Install driver:Copy and Paste the command line below:
One command line one line. Press Enter after pasting each command line to execute it.cd /Library/Extensions/chown -R root:wheel fabio.kextchmod 755 fabio.kextkextload fabio.kextNote: After pasting the last line, some may require a restart of the Mac.
7. Input a disc to the drive and then Run DVDFab to try again. Here is a copy of the info above as .pdf file:
Mac DVDFab repair_ command line - operation guide.pdfAdditionally, a video tutorial is available for your reference to demonstrate the process.
https://dl.dvdfab.cn/download/macOS-DVDFab13-drive-repair-installation-guides.mp4----------------------------------old contents----------------------------------------------
1. For users who never installed DVDFab 10/DVDFab11 beforeIf you never installed DVDFab 10/ DVDFab 11 on your Mac before, a window like this will pop out during the DVDFab installation process. At this point, you should click "Open Security Preferences" button, and then continue as shown in the next capture.
Now you should click the "Allow" button in the red rectangle to continue the installation process.
If you don't, DVDFab will not be able to read discs or burn DVD/Blu-ray folder/ISO file to blank discs.
2. For users who have installed DVDFab 10/DVDFab 11 but the software doesn't workFor users who have installed DVDFab 10/DVDFab 11 on your latest macOS High Sierra 10.13, you have probably found that DVDFab 10/DVDFab 11 cannot read or burn discs. Here is a fix for that particular problem:
First, you need to download and
install the latest DVDFab for Mac (v10.0.7.7 or later) on your computer.
Then, the next time you try to open a disc, a window will pop out to prompt you to repair the problem. Click the "
Repair" button, and after a while, the Security & Privacy window of Mac will pop out. Click the "Allow" and "Repair" button at the lower part on the window, and the problem should be fixed completely.
If the repair process fails, you will need to repair the problem by using terminal commands as shown below.3. Using Terminal to repair the problemFirst, click the "Go" and then choose the "Utilities" option.
Next, click the
"Terminal" to open the Terminal window.
And here comes two ways, normally, use the first one should fix the issue.
One is: Copy and paste the following commands to the Terminal line by line, it shall bring up the "
Allow" button which you can click on as shown on the above instruction.
cd /Applications/DVDFab\ 11.app/Contents/MacOS/
./fs.sh
The other is: copy and paste the following commands to the Terminal line by line.
sudo -s
(type your system password here)
kextload fabio.kextIt should look like this:
Finally, the "Security & Privacy" window pops out. Switch to "General" tab and click the
"Allow" button.
The problem which stopped you from opening disc or burning a disc is repaired.Note: You can also go to Finder > Applications > Utilities to find the Terminal and open it.
