Maal656 I'm using the MultiAVCHD program to create some basic Bluray menus (I'm not using the Bluray Creator module from DVDFab since it lacks some basic features like language selection menu).The problem is that when DVDFab Media Player is in full screen mode, the "rectangle" showing the option selected of the menu is not placed in its correct position. This does not hapen when program is not in full screen.Menu:Zoom to buttom (correctly shown in windowed mode):Zoom to buttom (incorrectly shown in full screen mode). As you can see the blue rectangle is shown moved downwards:I guess that maybe the problem is because my monitor has a 1680x1050 resolution, and real resolution from the Bluray (1920x1080) is resized in a different way for menu background and buttons, so they don't fit.Surely there are no many people affected by this problem, but it would be great to have it solved.Thanks.
Mona Hello Maal656,We will try to reproduce this problem first, thank you for the report.Regards,Mona
Maal656 Is there any way of sending you the menu of a Bluray created with multiavchd, without the movie? FTP, UPLOADED, or similar?
