ImgBurn as many settings other than just the layer break and burn speed. i will not get into these here but ImgBurn does have a good forum.
DVDFab Clone Mode will always keep the original layer break.
[QUOTE=scott7;2112]Thanks for your reply. I am assuming ImgBurn pops up with these layer break positions 'provided' that I have previously set DVDFab to remove the original layer break, right? [/QUOTE]
yes
From what you are saying, I assume I would need to go into common settings, "Protection" and then 'keep' the box checked where it says 'Remove Layer Break'. The default setting is with the box 'checked'. Keeping the box checked 'removes' the layer break. Of course, letting DVDFab remove the layer break would then give the option of ImgBurn of providing alternate layer break points during the burn process, right?
yes
However, this is what confuses me. I read in one post that it is best to 'uncheck' the box (when using DVD DL) which would then 'keep' the layer break in place versus what I wrote in the paragraph above. In the information I read elsewhere, I thought keeping the original layer break in place provided the best backup quality. Can you clarify? How does choosing an alternate layer break position provide a better outcome? Also, if I use ImgBurn, am I forced to select a layer break point versus allowing the system to choose it for me when using DVD DL?
i do not backup to Dual Layer so i can not properly answer.
I just want the best quality back when using DVD DL without getting too technical. I am assuming ImgBurn is the best choice in this scenario because it allows you to set the burn speed based on the MID (Media ID). Right?
Auto Write Speed, yes, by MID and by drive
