The developers know about the problem, please kindly wait for update, thank you.
Mona
There has already been one update since I started this topic.
I was using Passkey v9.3.2.0 when I started this topic.
Post 5 & 6 I had installed Passkey v9.3.2.1 .
I can wait for another update .
Here are a couple of things I've tested with the same results:
The computer I tested with Windows 7 32-bit has only SATA optical drives.
The computer I tested using Windows Vista 32-bit has only IDE optical drives.
I also installed some older versions of Passkey with the same results.
So it appears that this has not been working for a long time.
I know that commercial Audio CDs probably are not a priority .
Most don't even have any protection.
For those that do a software like Passkey is needed to run in the background & remove it. [h=2][/h]
