Thank you very much, Mona.
Newest Logs are Uploaded in GDrive Folder. I've tested it with AAC, Audio Copy, in combination with or without Subtitles, with Dev 11.0.3.9 and 11.0.4.0. Nothing changes. I think it's the B-Frame Support since 11.0.1.9, that clearly slows down the UHD Ripping. 11.0.1.8 runs very faster.
blasiusx
From developer:
We test on rtx1660, with or without B frame, DVDFab uses 100% nvenc video encode engine and your can see that in Windows 10 task manager or in GPU-Z sensors.
Enable B frame will use too much nvenc that is controlled by Nvidia driver, we send e-mail to Nvidia for support.
For mkv.4k.h265.10bit profile in DVDFab, you can open it (path "C:\Program Files\DVDFab 11\profiles6\preset\x265_ABR_Fast_MKV.preset"), go to line #39, find
4, change it to
0 and then you will have the old speed.
Meanwhile, you can also post this question on Nvidia forums.
