So... I have encoded my disc. Muxed to M2TS. From M2TS with UHD Creator to UHD BD and then with UHD Ripper do MP4.DolbyVision. Results are bad... tha framerate in MP4 is weird. When I create remux from original UHD disc, it's ok. But encoded file is also OK.
Source M2TS:
Format : BDAV
Format/Info : Blu-ray Video
File size : 11.7 GiB
Duration : 2 h 1 min
Overall bit rate mode : Variable
Overall bit rate : 13.7 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID : 6
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 233 cd/m2
Maximum Frame-Average Light Level : 63 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 391 MiB (3%)
Language : Czech
Service kind : Complete Main
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 640 kb/s
Bit depth : 16 bits
Stream size : 558 MiB (5%)
Language : English
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : Czech
Created UHD BD bdinfo (even here, check the missing HDR10+ in the video stream info, even when HDR10+ is present in M2TS file):DISC INFO:
Disc Title: alita_m2ts
Disc Size: 12,555,388,699 bytes
Protection: AACS2
Extras: Ultra HD
BDInfo: 0.7.5.3 (compatible layout created by DVDFab 11.0.3.9)
PLAYLIST REPORT:
Length: 2:01:57.309 (h:m:s.ms)
Total Bitrate: 13.73 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 9739 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020 /
* MPEG-H HEVC Video 2134 kbps 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
AUDIO:
Codec Language Bitrate Description
Dolby Digital Audio Czech 448 kbps 5.1 / 48 kHz / 448 kbps
Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics Czech 21.606 kbps
Created MP4.DolbyVision (check that framerate and duration... all bad):Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom/hev1/dby1)
File size : 11.1 GiB
Duration : 2 h 22 min
Overall bit rate : 11.1 Mb/s
Movie name : ALITA_M2TS.Title0
Writing application : DVDFab 11.0.3.9
Video #1
Format : HEVC
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 8 334 kb/s
Frame rate mode : Variable
Frame rate : 20.515 FPS
Minimum frame rate : 11.976 FPS
Maximum frame rate : 24.024 FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.049
Stream size : 8.30 GiB (75%)
Codec configuration box : hvcC
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 2 135 kb/s
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.043
Stream size : 1.82 GiB (16%)
Codec configuration box : hvcC+dvcC
Audio #1
Format : AC-3
Codec ID : ac-3
Bit rate : 448 kb/s
Bit depth : 16 bits
Title : Czech (ac3 5.1)
Language : Czech
Default : Yes
Alternate group : 1
Audio #2
Format : AC-3
Codec ID : ac-3
Bit rate : 640 kb/s
Bit depth : 16 bits
Title : English (ac3 5.1)
Language : English
Default : No
Alternate group : 1
