The logs you need to supply for this disc are:
1) DVDFab internal log and
2) PathPlayer log. Leave PathPlayer enabled to make this log.
Then ATTACH the logs to a post, do not place parts of them in the message area of the post as you did above, which was incomplete and not really useful.
signals
What I pasted was the log that appeared while selecting the information button, that appears in the DVD COPY mode.
Disabling Pathplayer, the program does not remove anything.
Would this be this log correct?
I am unable to get anything from the pathplayer.log file. Whenever I open it, there only appear some unreadable texts.
DVDFab 11.0.7.9 (2020/03/31 03:33:06) (X64)
2020.03.31-03:33:06: Init Public log: enabled.
2020.03.31-03:33:06: Init Private log: finish.
2020.03.31-03:33:06: App info: 2020-3-16
2020.03.31-03:33:06: App info: 11.0.7.9 11079 Official
2020.03.31-03:33:06: Init CrashReportSettings: enabled.
2020.03.31-03:33:06: Init DVDInfo_Log: enabled.
2020.03.31-03:33:06: app info: compiled time Mar 16 2020 19:06:06
2020.03.31-03:33:06: code page is 0
2020.03.31-03:33:06: app args: count 2,arg 0:C:\Program Files\DVDFab 11\DVDFab64.exe,arg 1:--internal,
2020.03.31-03:33:06: Init Qt_Log: disabled.
2020.03.31-03:33:06: Profile Manager :: Begin Load Profile
2020.03.31-03:33:06: Qt Translator file load success
2020.03.31-03:33:06: App info: client type 44.
2020.03.31-03:33:06: MobilePlay load: preload successful.
2020.03.31-03:33:06: MobilePlay load: Load successful.
2020.03.31-03:33:06: Init process: Transfer settings successful.
2020.03.31-03:33:06: info: check logpath= C:/Users/Luigi/Documents/DVDFab11/Log/
2020.03.31-03:33:06: info: _check_gpu is running ...
2020.03.31-03:33:07: info: check_gpu run successful
2020.03.31-03:33:07: info: recommand= 851968, Shrink support= 1, enable= 1, cuda_cap= 0 , cpu_count= 4
2020.03.31-03:33:07: GPU check: GPUAccelerate-0XD0005
2020.03.31-03:33:07: GPU check: GPUAccelerate setting-0XD0000, 0XD0000
2020.03.31-03:33:07: GPU check: CUDA cap-0X0
2020.03.31-03:33:07: GPU check: Support coreavc decode-0
2020.03.31-03:33:07: GPU check: Lighting shrink status-1, 1
2020.03.31-03:33:07: GPU check: Graphics info 1: Intel(R) HD Graphics : 10.18.10.4358 : 11,4 : 0G
2020.03.31-03:33:07: Init process: Load config failed.
2020.03.31-03:33:07: Server check: Set current server 0.
2020.03.31-03:33:07: MobilePlay load: preload successful.
2020.03.31-03:33:07: MobilePlay load: Load successful.
2020.03.31-03:33:07: Init process: Windows os type is 64bit System Windows 10 Build 18362.
2020.03.31-03:33:07: Init process: appUuidForLastRun=b8f22692-8d6c-483f-b7a2-083ce5dc9e96, appUuidForThisRun=f4c0d2a8-2cd8-4048-b112-80c35e3c4543
2020.03.31-03:33:07: Init process: command line in is --internal
2020.03.31-03:33:07: ShowStartupDialog: true
2020.03.31-03:33:09: Profile Manager :: End Load Profile
2020.03.31-03:33:09: 6e4cbbf086bb83ac7929b1eac0eaf2d2-e84edecf545c66a80314e92602eb4b74-67c917850fef782b827bad658400e160-2127117d82f2bcf6eb34c7beed82b32b-b4c27b30a7465181cb3f6b4a5b77276b
2020.03.31-03:33:09: Option check status-Reduce one time.
2020.03.31-03:33:09: Option check status-L
2020.03.31-03:33:09: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:0:0 )-( DVD to Mobile:1:0 )-( Blu-ray to Blu-ray:0:0 )-( UHD to Blu-ray:1:0 )-( Blu-ray to Mobile:1:0 )-( File to Mobile:1:0 )-( Blu-ray to DVD:1:0 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File to Blu-ray UHD:1:0 )-( File Mover:1:0 )-( Blu-ray to 3D:1:0 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-( CinaviaRemoval HD:1:0 )-( DVD Cinavia Removal:1:0 )-( Blu-ray Cinavia Removal:1:0 )-( UHD Cinavia Removal:1:0 )-( DRM Removal:1:0 )-( iOS Recorder:1:0 )-( YouTube to MP3:1:0 )-( UHD Drive Tool:0:0 )-( Video Downloader:1:0 )-( Hi-Fi Audio Converter:1:0 )-( UHD Copy:1:0 )-( UHD Ripper:1:0 )-( Youtube Video Download:1:0 )-( Enlarge AI:1:0 )-
2020.03.31-03:33:09: App info: language type ESP.
2020.03.31-03:33:09: App info: Install path C:/Program Files/DVDFab 11/
2020.03.31-03:33:09: Start checking run condition!
2020.03.31-03:33:09: Start check: begin
2020.03.31-03:33:09: Export Blu-ray source information report: enabled
2020.03.31-03:33:09: Init process: Init GPU settings successful.
2020.03.31-03:33:09: SUCCEED: IServerService WebServer Init succeed.
2020.03.31-03:33:09: SUCCEED: IServerService MediaLibrary Init succeed.
2020.03.31-03:33:10: Get cinavia info,(0,1)
2020.03.31-03:33:10: Serial number is: 74-c6-3b-60-05-21:d0-17-c2-ca-db-e5
2020.03.31-03:33:10: Connect type is: 0
2020.03.31-03:33:11: Times of connecting server is: 0
2020.03.31-03:33:11: FabAuthorize: CheckOption - success
2020.03.31-03:33:11: Option check status-N
2020.03.31-03:33:11: Server check: update share memory to 0.
2020.03.31-03:33:11: Start check: end
2020.03.31-03:33:13: Plugin Info: 3 exits flag = false plugin path = C:/Program Files/DVDFab 11/Plugins/IOSRecorder.xml
2020.03.31-03:33:13: Plugin Info: 4 exits flag = false plugin path = C:/Program Files/DVDFab 11/Plugins/DRMRemoval.xml
2020.03.31-03:33:13: Plugin Info: 5 exits flag = false plugin path = C:/Program Files/DVDFab 11/Plugins/YoutubeToMP3.xml
2020.03.31-03:33:13: Plugin Info: 6 exits flag = true plugin path = C:/Program Files/DVDFab 11/Plugins/UHDDriveTool.xml
2020.03.31-03:33:14: Burn engine: start init.
2020.03.31-03:33:14: Burn engine: set log folder.
2020.03.31-03:33:14: DVD: init read settings.
2020.03.31-03:33:14: DVD: init write settings.
2020.03.31-03:33:14: Init BurnLog : file(C:/Users/Luigi/Documents/DVDFab11/Log/burn_internal.log)
2020.03.31-03:33:14: BD: init read settings.
2020.03.31-03:33:14: BD: init write settings.
2020.03.31-03:33:14: bd set region A
2020.03.31-03:33:14: Burn engine: config engine type-3 begin.
2020.03.31-03:33:14: Burn engine: config engine type-3 end.
2020.03.31-03:33:14: Burn engine: writer count 2.
2020.03.31-03:33:14: Burn engine: 0-F:\ [ASUS DRW-24D5MT].
2020.03.31-03:33:14: Burn engine: 1-E:\ [ASUS BC-12D2HT].
2020.03.31-03:33:14: Burn engine: end init.
2020.03.31-03:33:21: Init process: Init setting page successful.
2020.03.31-03:33:21: ShowStartupDialog: false
2020.03.31-03:33:21: QtLog Mode = false
2020.03.31-03:33:26: Start show MainUI.
2020.03.31-03:33:26: dpi scale: x scale 1.000000
2020.03.31-03:33:26: dpi scale: y scale 1.000000
2020.03.31-03:33:26: dpi scale: real scale 1.000000
2020.03.31-03:33:26: dpi scale: system real scale 1.000000
2020.03.31-03:33:26: Init process: init main ui successful.
2020.03.31-03:33:26: UI manager: switch to Copy mode.
2020.03.31-03:33:26: Init process: show main ui successful.
2020.03.31-03:33:26: Cinavia Version : 1.346.2.105.1.28
2020.03.31-03:33:26: DriveX msg: Init driveX E with I/O mode: 0
2020.03.31-03:33:26: DriveX msg: Init driveX F with I/O mode: 0
2020.03.31-03:33:26: opened i/o type 2
2020.03.31-03:33:26: opening drive F
2020.03.31-03:33:26: currentProfile: 16
2020.03.31-03:33:26: got media type 4
2020.03.31-03:33:26: got max lba 2860897
2020.03.31-03:33:26: scene data: delete file C:/Users/Luigi/AppData/Roaming/DVDFab11/SceneData/71319b09-dbb2-4fca-8bb2-46da57165836.SceneData.xml result=1
2020.03.31-03:33:26: scene data: delete dir C:/Users/Luigi/AppData/Roaming/DVDFab11/SceneData/71319b09-dbb2-4fca-8bb2-46da57165836 result=0
2020.03.31-03:33:26: before exec()
2020.03.31-03:33:27: MessageCenter: Update message successfully!
2020.03.31-03:33:28: got disc type 10
2020.03.31-03:33:28: type DVD-VIDEO
2020.03.31-03:33:28: volume label BIG_FAT_LIAR
2020.03.31-03:33:28: Is Encryption 1
2020.03.31-03:33:28: DriveX msg: media open(false) success in driveX F.
2020.03.31-03:33:28: got drive Inquiry!
2020.03.31-03:33:28: drive Inquiry!
2020.03.31-03:33:28: DriveX msg: add media success in driveX F.
2020.03.31-03:33:28: DriveX msg: send open media msg to thread for driveX F.
2020.03.31-03:33:29: opened i/o type 2
2020.03.31-03:33:29: opening drive E
2020.03.31-03:33:29: currentProfile: 0
2020.03.31-03:33:29: got drive Inquiry!
2020.03.31-03:33:29: drive Inquiry!
2020.03.31-03:33:29: Drive Version: E, 3.00
2020.03.31-03:33:29: got firmware ASUS BC-12D2HT 3.00.
2020.03.31-03:33:29: Source manager: open source flag:1,0,1,1,1
2020.03.31-03:33:29: Is Encryption 1
2020.03.31-03:33:29: Drive Version: F, 1.00
2020.03.31-03:33:29: got firmware ASUS DRW-24D5MT 1.00.
2020.03.31-03:33:29: Source manager: add source id 0.
2020.03.31-03:33:29: Source open status:DVD No, 2000-1-1, No
2020.03.31-03:33:29: Source open status:BD No, 2000-1-1, No
2020.03.31-03:33:29: Source open status:UHD Yes, 2158-1-1, No
2020.03.31-03:34:00: Begin to open drivex: F
2020.03.31-03:34:00: opened i/o type 2
2020.03.31-03:34:00: opening drive F
2020.03.31-03:34:00: currentProfile: 16
2020.03.31-03:34:00: got max lba 2860897
2020.03.31-03:34:00: got disc type 10
2020.03.31-03:34:00: Is Encryption 0
2020.03.31-03:34:01: internal path F:/VIDEO_TS/
2020.03.31-03:34:01: got copyright 1 fd
2020.03.31-03:34:01: key method 0
2020.03.31-03:34:02: got udf/iso
2020.03.31-03:34:02: dvd discid 3234303839343134373736363233363831363600
2020.03.31-03:34:02: dvd enable cloud decryption
2020.03.31-03:34:02: server id 0
2020.03.31-03:34:04: got discinfo
2020.03.31-03:34:04: pathplayer enabled
2020.03.31-03:34:06: button: vts_0 menu_1 pgc_1 cell_1 start_374 end_401 sector_374 count_3
2020.03.31-03:34:07: button: vts_1 menu_1 pgc_1 cell_1 start_374 end_406 sector_374 count_5
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_6 cell_1 start_468 end_517 sector_468 count_10
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_7 cell_1 start_518 end_562 sector_518 count_10
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_8 cell_1 start_563 end_608 sector_563 count_10
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_9 cell_1 start_609 end_655 sector_609 count_10
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_10 cell_1 start_656 end_694 sector_656 count_8
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_3 cell_1 start_439 end_467 sector_439 count_4
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_2 cell_1 start_407 end_438 sector_407 count_6
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_1 cell_2 start_895 end_935 sector_895 count_5
2020.03.31-03:34:15: button: vts_1 menu_1 pgc_1 cell_3 start_1150 end_1195 sector_1150 count_5
2020.03.31-03:34:16: server id 0
2020.03.31-03:34:17: full disc copy/play is supported
2020.03.31-03:34:20: server id 0
2020.03.31-03:34:21: server id 0
2020.03.31-03:34:22: got dvdinfo
2020.03.31-03:34:22: opened dvd
2020.03.31-03:34:22: End open drivex: F
2020.03.31-03:34:23: Source manager: open 0 successful.
2020.03.31-03:34:25: StartSyncMetaInfoThread begin, 0
2020.03.31-03:34:27: error curl get: Failure when receiving data from the peer
2020.03.31-03:34:28: Work manager: create DVD fulldisc work 0 with source 0 and uiinfo 0.
2020.03.31-03:34:28: error curl get: Failure when receiving data from the peer
2020.03.31-03:34:28: Meta: the ownership is E_Meta_No_Owner.
2020.03.31-03:34:28: Meta: editable flag is META_INFO_EDITABLE_FLAG_NOT_FOND
2020.03.31-03:34:28: UiLog: nfo: scraper name BIG_FAT_LIAR year .
2020.03.31-03:34:28: NFO: scraper Movie Data. av false.
2020.03.31-03:34:29: NFO: update Data. av false.
2020.03.31-03:34:29: UiLog: nfo: scraper Data success.
2020.03.31-03:34:29: StartSyncMetaInfoThread End, 0
2020.03.31-03:34:30: Source manager: open source flag:1,0,1,1,1
2020.03.31-03:34:40: MoviePoster Log: Volume(BIG_FAT_LIAR), DiscID(2408941477662368166)
2020.03.31-03:35:17: Exit process: processBeforeClose.
2020.03.31-03:35:17: Exit process: clear temp folder.
2020.03.31-03:35:17: Exit process: stop quality task.
2020.03.31-03:35:17: Exit process: stop thumbnail thread.
2020.03.31-03:35:17: Exit process: save config file.
2020.03.31-03:35:17: Upload backup data success.
2020.03.31-03:35:19: Exit process: create jump list.
2020.03.31-03:35:19: Exit process: save meta info to local file.
2020.03.31-03:35:19: Exit process: stop running.
2020.03.31-03:35:19: Init preview: Load plcore dll failed, error( 126 )
2020.03.31-03:35:19: Exit process: finish MainUI.
2020.03.31-03:35:19: Exit process: finish FreePref.
2020.03.31-03:35:19: Exit process: finish AVEditWrap Release.
