Hello,
I created in the past successfully AVCHD/BD5 to DVD-R with DVDFab Version 8 & 9 for playing on my Panasonic Blu-ray Player DMP-BD85.
The player played all discs very well without any problems. It works in 720p and 1080p.
But now with latest DVDFab x64 11.x.x.x Blu-ray Copy module, the discs are unsupported on my Player. So I thought the Player is the problem.
But tried also with a Panasonic DMP-BDT220 and LG UBK90 --> Discs are unsupported/not playable. Depends not on the movie, happens with every.
What I do:
- copy the whole disc/mainmovie without compression to HDD
- copy only the mainmovie to BD5/1080
- For burning I used Nero, CDBurnerXP or ImgBurn always with UDF 2.50
- tried different settings with or w/o certificate folder
And very strange, when I take a old movie, created with DVDFab 8 or 9, I could succesfully burn the BDMV folder and all the mentioned player plays the movie.
So I guess the problem should be somewhere in DVDFab. I'm wondering why DVDFab 11 creates more folders in BDMV (Auxdata, BDJO, JAR & META). Version 8 & 9 didn't do that.
My OS is Win 10 1909, Intel Xeon E5-1620 v3, 24 GB RAM, internal drives: HL-DT-ST BD-RE BH10LS30 & HP DVDRAM GUB0N
Would be very helpful if somebody knows what could be the solution.
Thank you
