Buckle in.. this will get technical. I converted a blu-ray of Doctor Sleep and watched it on my big screen. I was disappointed with the overall quality. There were lot's of digital artifacts especially in low light scenes. That started me down the road of measuring the quality of various settings in version 11 and now version 12. Using the VMAF tool, I measure a few different clips of the video using various settings in dvdfab and then also against a FFMPEG encoded version utilizing NVENC since I have an Nvidia 20XX Turing card.
Here are some results:
LRLS = Lightning Record/Lightning Shrink (Nvidia 2070 Turing Card)
SW = Software Encoder (No acceleration)
SQ/HQ = Standard Quality/High Quality
1Pass/2Pass = Encoding Passes
VMAF is out of 100, PSNR out of 60, and MS_SSIM out of 1
FFMPEG used NVENC encoding/decoding with a 5Mb/s VBR and 8Mb/s Max
Clip 1 [TABLE="border: 1, cellpadding: 1, width: 500"]
[TR]
[TD]DVD Fab Version[/TD]
[TD]Encoding Settings[/TD]
[TD]VMAF Score[/TD]
[TD]PSNR Score[/TD]
[TD]MS_SSIM Score[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]LRLS HQ 2Pass[/TD]
[TD]87.9577[/TD]
[TD]44.5194[/TD]
[TD]0.995780[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]LRLS SQ 1Pass[/TD]
[TD]87.7419[/TD]
[TD]44.5210[/TD]
[TD]0.995719[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]SW SQ 1Pass[/TD]
[TD]78.5874[/TD]
[TD]42.3323[/TD]
[TD]0.994097[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]88.0855[/TD]
[TD]44.3956[/TD]
[TD]0.997606[/TD]
[/TR]
[TR]
[TD]FFMPEG[/TD]
[TD]NVENC_8M_1Pass[/TD]
[TD]94.6138[/TD]
[TD]49.9948[/TD]
[TD]0.998656[/TD]
[/TR]
[/TABLE]
Clip 2 [TABLE="border: 1, cellpadding: 1, width: 500"]
[TR]
[TD]VMAF Score[/TD]
[TD]PSNR Score[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]71.8197[/TD]
[TD]30.5846[/TD]
[TD]0.975837[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]70.5031[/TD]
[TD]30.5202[/TD]
[TD]0.973363[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]46.0894[/TD]
[TD]27.0846[/TD]
[TD]0.935390[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]71.7805[/TD]
[TD]30.5739[/TD]
[TD]0.983692[/TD]
[/TR]
[TR]
[TD]FFMPEG[/TD]
[TD]95.7707[/TD]
[TD]42.3496[/TD]
[TD]0.995377[/TD]
[/TR]
[/TABLE]
Clip 3 [TABLE="border: 1, cellpadding: 1, width: 500"]
[TR]
[TD]VMAF Score[/TD]
[TD]PSNR Score[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]73.3437[/TD]
[TD]37.1798[/TD]
[TD]0.982553[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]72.8649[/TD]
[TD]37.1548[/TD]
[TD]0.981832[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]56.2030[/TD]
[TD]34.3361[/TD]
[TD]0.968179[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]73.5675[/TD]
[TD]34.3361[/TD]
[TD]0.968179[/TD]
[/TR]
[TR]
[TD]FFMPEG[/TD]
[TD]94.4231[/TD]
[TD]46.1366[/TD]
[TD]0.997327[/TD]
[/TR]
[/TABLE]
To ensure that the clipping wasn't a major cause (even though I was using a mostly frame-copy clipping tool) I also ran an analysis on the entire video with similar results:
Entire Movie [TABLE="border: 1, cellpadding: 1, width: 500"]
[TR]
[TD]VMAF Score[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]78.5058[/TD]
[/TR]
[TR]
[TD]FFMPEG[/TD]
[TD]94.3652[/TD]
[/TR]
[/TABLE]
I also repeated this test with two other movies and saw similar results. It is obvious to me that
- SW Encoding is maximizing speed over quality. Not unexpected of since SW Encoding can take a long time on most HW. Would be nice though to have the different profile qualities be more inline with x264 in general. It is not very good at the default settings. CABAC is disabled, CBR 9Mb/s, 8x8DCT is disabled so on.
- The LRLS settings for NVENC are not optimized for newer Nvidia HW. I also tried with a previous generation 1070 card with similar results
- FFMPEG at only 5Mb/s is generating a much higher quality file than DVDFab at 9.1Mb/s when both using Nvidia for encoding
- 2Pass Encoding isn't worth it and in general using HQ over SQ isn't worth it considering the change in file size
- DVDFab 12 has cranked up the bitrate on SQ to 9Mb/s but I see very minimal difference in the overall quality improvement
I cannot find any way to update the settings used for LR or LS. Is there anyway to change those settings? I did find a setting for B-frame support for Turing cards and enabled it, but there was minimal difference.
Any hidden switches for the HW based encoding?
--Bill
