I tried a few third party products with Passkey 7.0.0.5 for Inglorious Basterds and there are a few problems with it.
1. With Dvd Decrypter, when it's time to copy any BUP file, it pops up an error like the following:[code]On-the-fly IFO/BUP file patching failed!
Filename: VTS_01_0.BUP
Reason: Invalid IFO/BUP file[/code]
2. With DVD Shrink, the full disc dvd-9 copy is successful.
3. When opening the files ripped by Dvd Decrypter in DvdReMake Pro, it cannot read the VTS3. The same thing happens when opening DVD Shrink ripped files. I always use DvdReMake Pro and/or PgcEdit to double-check if DvdFab or any ripper product to see if a DVD is properly created according to DVD specs. The error that DRMP reports is:
[code]Importing DVD...
Read DVD from: L:\INGLOURIOUS_BASTERDS\DVDSHRINK\VIDEO_TS
Read VMG
Read VTS1
Read VTS2
Read VTS3
Recovering C_ADT & VOBU_ADMAP tables. (818:VobData.cpp)
can't find segment (1007:VobData.cpp)
Can't open title set vob - will substitute blanks. (881:VTS.cpp)
Cell #1 uses vobus (vobID=1, cellID=2) not pressent in vob file. Substituting blank cell instead. (2117:PGC.cpp)
Cell #2 uses vobus (vobID=1, cellID=4) not pressent in vob file. Substituting blank cell instead. (2117:PGC.cpp)
Cell #3 uses vobus (vobID=1, cellID=6) not pressent in vob file. Substituting blank cell instead. (2117:PGC.cpp)
Cell #4 uses vobus (vobID=2, cellID=1) not pressent in vob file. Substituting blank cell instead. (2117:PGC.cpp)
Cell #5 uses vobus (vobID=3, cellID=1) not pressent in vob file. Substituting blank cell instead. (2117:PGC.cpp)
Read VTS4
Read VTS5
Read VTS6
Read VTS7
Read VTS8
Read VTS9[/code]
4. When opening the files ripped by Dvd Decrypter in PgcEdit, it pops up a message:
[code]There are some VOB files in your DVD folder that are not referenced by the current IFOs:
VTS_02_0.VOB
VTS_02_1.VOB
VTS_03_0.VOB
VTS_04_0.VOB
VTS_05_0.VOB
VTS_06_0.VOB
VTS_07_0.VOB
VTS_07_1.VOB
VTS_08_0.VOB
VTS_09_0.VOB
You should remove them now. (Recommended)[/code]
From Dvd Shrink ripped files, PgcEdit reports:
VTS_02_1.VOB
VTS_07_1.VOB
5. With Passkey enabled, I cannot open any DVD in the DVD drive with DvdReMake Pro. It freezes in the middle of reading process. For PgcEdit, it opens fine for this title but obviously it cannot save the DVD directly to a DVD media itself. So Passkey is meant only to work with a ripper software and a software player only, not with DVD editors.
So, there are some bugs to iron out. btw, just see a 7.0.0.6 release, but the only thing that's new is the balloon tooltip.
Forgot to mention that DVDFab 7.0.1.2 has no problem ripping and that both DVD editors report no serious errors.
