As I reported the other day, when I start downloading audio, the download progresses by more than 3% and fails randomly.
Then, after a while, I was able to download the content that had failed before, and I suspected that it was my environment, but since the same symptoms occur on multiple PCs, it is not a problem on StreamFab's side. I think so.
Version used: x64 6.1.4.3
Thank you for your response.
