I really do not like the new User Interface for DVDFab 13, but I suppose I will eventually get used to it. However, I am also finding several specific problems.
This first one is very minor - but a problem none-the-less:
When first installed, the Common Settings, Sounds, does not have any sound files specified for either Success or Fail. I was able to find them manually, and then they work as normal, but they should not be left blank on installation.
I am still testing other problems with the UI, so I will report on those in new threads next week.
