I’m burning MKV movie files to UHD Blu-ray discs. When I select the MKV source file I’m presented 2 audio tracks. The first one is in Italian and is checked in the box, the second audio track is in English and no check in the box. I only want the English audio track so I check the English box and remove the check in the Italian box. Preview has the Italian audio track playing and burning a disc results that both audio tracks are there with the Italian as the first(default) which is wrong. There shouldn’t be any Italian audio at all. This only happens with DVDfab13.
DVDfab12 works correctly the resulting Preview, ISO file, and burned UHD disc only has the English audio track.
I have created many UHD discs with English audio only from MKV source files that have both Italian/English audio tracks using DVDfab12. It works as it should.
Thus DVDfab13 is not the same as DVDfab12 in the UHD Creator mode regarding audio selection.
Any fix?
Pass this on to the developers.
