Everytime I want to enlarge a video, I allways get an error message "Failed". I am not able to enlarge any video.
In the logfile I found the following lines:
3120 12.10 19:49:02.5(0x1064)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_MSG pszEventID= pszMsg=Conversion: one pass MsgType=0 dwStatusResID=0
3120 12.10 19:49:02.5(0x4fec)L: info: begin render pin
3120 12.10 19:49:02.5(0x4fec)L: info: args: video_size=720x480:pix_fmt=0:time_base=1001/30000:pixel_aspect=853/720
3120 12.10 19:49:02.5(0x4fec)L: info: video_filter: scale=853:480,pad=854:480:'abs(ow-iw)'/2:'abs(oh-ih)'/2 :black
3120 12.10 19:49:02.5(0x4fec)L: info: ex process path= C:/Users/Hans-Hartwig Hein/AppData/Roaming/DVDFab/UniFab/EnlargeAI/video/EncodeCore.exe
3120 12.10 19:49:02.5(0x4fec)L: info: win wstr_param (C:/Users/Hans-Hartwig Hein/AppData/Roaming/DVDFab/UniFab/EnlargeAI/video/EncodeCore.exe)
3120 12.10 19:49:02.5(0x4fec)L: error: win CreateProcess: wstr_param (C:/Users/Hans-Hartwig Hein/AppData/Roaming/DVDFab/UniFab/EnlargeAI/video/EncodeCore.exe -n c30-000002063180F150-815-comm-fifo 8388608 unifab64.exe 3120 "E:/Hans-Hartwig Hein/Documents/DVDFab/UniFab/Log/" "C:/Program Files/DVDFab/UniFab/") failed
3120 12.10 19:49:02.5(0x4fec)L: error: error: control process (external_process create_process_fail 0)
3120 12.10 19:49:02.5(0x4fec)L: error: task_convert external_process create_process_fail 0
3120 12.10 19:49:02.6(0x1064)L: WorkManagerProcessInfo: EventInfoNotify: EVENT_MASK_MSG pszEventID= pszMsg=Work 1 failed, Error = external_process create_process_fail 0 MsgType=2 dwStatusResID=0
3120 12.10 19:49:02.6(0x4fec)L: error: Work 1 failed, Error = external_process create_process_fail 0
3120 12.10 19:49:02.6(0x4fec)L: ------------------ convert work failed ------------------
3120 12.10 19:49:02.6(0x4fec)L: ------------------ all convert work cancelled -------------------
3120 12.10 19:49:02.6(0x4fec)L: WorkControl: return value is 10, user do not clicked cancel.
3120 12.10 19:49:02.6(0x4fec)L: WorkControl: end user copy.
3120 12.10 19:49:02.6(0x4fec)I: work: work_status: ui WorkData status changed to WorkData_Failed
What can I do?
Thank You in advance.
