AI Audio Upmixer does not work. When it first came back it would not download the modules, you fixed that and it does not work at all. It did downloard the modules but the first movie 2.0 to 5.1 upmix it got stuck at 0.02 and after waiting the time was at 568:59:68. Tried two different movie and it appeared to work at a reasonable speed however there was no audio output. VLC media player codeec info showed no audio format however Playerfab shows eac3-5.1 and no audio in either. I then loaded the movie into the Converter and it identified as "AAC (Same as Source)", Channels - empty, "Sample Rate - 0KHz (Same as Source)", "Bit Rate - 128kbps". At least when you first introduced Audio AI it worked. I notice the price has gone up from $69.99 full features, then you removed a feature capability while keeping the same price, now adding that capability back and added $30 to the price, and it doesn't even work - at all. I actually used to say DVDfab was the best but now since the focus has changed from a quality product to a money grab I could never recommend DVDfab to any one. C'mon, get it together!
