do downloads fail on both MP4 & MKV ??
can you download anything below 720p ?
october262
I normally download as MKVs, so I just tried MP4s. Still fails even if I specify a trivial resolution--well below 720.
The reason I suspected a MAX DRM or similar change is because of StreamFab's bizarre behavior. It immediately appears to misjudge the file type, suggests the video is 0KB, and attempts for less than a second to download the video at 500
BYTES/Second, jumps directly to trying to download the audio (while flipping back and forth between EAC3 and AAC), and then fails. These same videos play perfectly from within Max on my TV and iPhone. Hell, they even play in StreamFab's browser window. And yet StreamFab still works perfectly for downloads fromHulu.
At least one other user has replied that Max is still working fine for him. If there are others who have or do not have this issue with Max and could chime in with "It works for me" or "It doesn't work for me", it would help determine whether this is a universal issue or just something affecting a few of us.
