are the subtitles correct if you select "Extract to SRT file" click
settings - preferences - VIP services - preferred settings - under subtitle action - select extract to srt file from
the drop down menu.
october262
I always download subtitles in external .srt files because if there is something wrong, I like to correct them. But here it is impossible to do it! (Maybe in this case, though, I could try the opposite. I could try downloading an episode with internal subtitles. Yes, I will give this a try). :rolleyes:
