Also no problem in Serbia
Take a look at the times - analysis Max + SkyShowtime ended by cancel at the same time:
[code]2024:12:12-21:33:58 0x00000cac [Log]: DRMLocalServer: receive all msg elk:{"failure_reason":"","pid_web":"909","reg_status":"reg_enable","result":"cancel","title":"","type":"analyze","url":"","website":"Max"}
2024:12:12-21:33:58 0x00004d64 [Log]: DRMLocalServer: receive all msg elk:{"failure_reason":"","pid_web":"956","reg_status":"reg_enable","result":"cancel","title":"","type":"analyze","url":"","website":"SkyShowtime"}[/code]
That's probably your problem, you seem to want too much at the same time.
