diloume67 Hello, with the Macbook Pro M4 Max the videoToolbox encode not work with the H.265, only the H264 is ok...Whats the problem ?Thank for answer....
diloume67 It seems that the problem appears with version 13.0.3.3. I see the same thing on a Macbook Pro M3Pro. Is it otherwise a re-build of the unregistered version?
myhotpants56 the latest version of apple silicon dvd fab is slow and does not use gpu acceleration at all. disc copy (bluray) is burning at maximum 0.9x while the old version did it at 5x and less than 10 mins. now I'm waiting 1 hour or more to burn 1 disc...terrible
