We got a biggie released today - yt-dlp 2025.06.09 (aka YoutubeToMP3Process after modification).
If all goes as promised, AdobePass for NBC, Turner, and a few other shows will be fixed. Added MSO for Fubo and Philo.
yt-dlp 2025.06.09
Extractor changes
Improve JSON LD thumbnails extraction (#13368) by bashonly, doe1080
10play: Fix extractor (#13349) by bashonly
adobepass
Add Fubo MSO (#13131) by maxbin123
Always add newer user-agent when required (#13131) by bashonly
Fix Philo MSO authentication (#13335) by Sipherdrakon
Rework to require software statement (#13131) by bashonly, maxbin123
Validate login URL before sending credentials (#13131) by bashonly
aenetworks
Fix playlist extractors (#13408) by Sipherdrakon
Fix provider-locked content extraction (#13131) by maxbin123
bilibilibangumi: Fix extractor (#13416) by c-basalt
brightcove: new: Adapt to new AdobePass requirement (#13131) by bashonly
cu.ntv.co.jp: Fix extractor (#13302) by doe1080, nullpos
go: Fix provider-locked content extraction (#13131) by bashonly, maxbin123
nbc: Rework and adapt extractors to new AdobePass flow (#13131) by bashonly
nobelprize: Fix extractor (#13205) by doe1080
odnoklassniki: Detect and raise when login is required (#13361) by bashonly
patreon: Fix m3u8 formats extraction (#13266) by bashonly (With fixes in 1a8a03e)
podchaser: Fix extractor (#13271) by bashonly
sr: mediathek: Improve metadata extraction (#13294) by doe1080
stacommu: Avoid partial stream formats (#13412) by bashonly
startrek: Fix extractor (#13188) by doe1080
svt: play: Fix extractor (#13329) by barsnick, bashonly
telecinco: Fix extractor (#13379) by bashonly
theplatform: Improve metadata extraction (#13131) by bashonly
toutiao: Add extractor (#13246) by doe1080
turner: Adapt extractors to new AdobePass flow (#13131) by bashonly
twitcasting: Fix password-protected livestream support (#13097) by bashonly
twitter: broadcast: Support events URLs (#13248) by doe1080
umg: de: Rework extractor (#13373) by doe1080
vice: Mark extractors as broken (#13131) by bashonly
vimeo: Extract subtitles from player subdomain (#13350) by bashonly
watchespn: Fix provider-locked content extraction (#13131) by maxbin123
weverse: Support login with oauth refresh tokens (#13284) by bashonly
youtube
Add tv_simply player client (#13389) by gamer191
Extract srt subtitles (#13411) by gamer191
Fix --mark-watched support (#13222) by brian6932, iednod55
Fix automatic captions for some client combinations (#13268) by bashonly
Improve signature extraction debug output (#13327) by bashonly
Rework nsig function name extraction (#13403) by Grub4K
nsig code improvements and cleanup (#13280) by bashonly
zdf: Fix language extraction and format sorting (#13313) by InvalidUsernameException
Misc. changes
build
Exclude pkg_resources from being collected (#13320) by bashonly
Fix macOS requirements caching (#13328) by bashonly
cleanup: Miscellaneous: 339614a by bashonly
test: postprocessors: Remove binary thumbnail test data (#13341) by bashonly
No excuses, this needs to be added to this week's update.
