Well untill I can get this solved would it hurt for me to just authenticate while using my VPN for the time being and grab what shows I need to get? Or I shouldn't be authenticate while using VPN? I have express.
AceDaMack
It's to the point that if using a VPN lets you activate/authenticate, then I guess keep doing it. Once activated/authenticated, if possible, then turn off the VPN. If not, then no choice but to leave it on.
Try to stay on local VPN servers if possible as well.
It's NOT a streamfab server issue unless it's something connected directly with your streamfab account causing this, as if it were a streamfab server issue, the forum would be littered with reports.
I have to conclude and agree with
jpp72 that it is possibly a DNS issue; most people use the defaults their ISP gives them, but at any time, such ISP can then block people from sites.
I lean towards OpenDNS and Cloudflare DNS, a list is (
here), I would also say stay away from any offering any type of blocking or filters, including ad blocking.
I remember back in the day when my ISP blocked users from a very popular ------ site, and it continued to others all with different ISP's so we had to change DNS servers or use an unblock website to unblock the blocked websites. Or even Proxies and VPN's.
Maybe after a long weekend, try SF feedback/support again, they usually don't answer during weekends.
