can you try ep1 or ep2 where im getting 720p for h264 to see if you get the 1080p?
psych22
s10e01+02 are offered in maximal 720 with H264 ..
.. that's why I wrote "s10 is only offered in H264 720p"
No one can get this from Max because Max doesn't offer it.
You can force the analyzing of a single episode
with manually analyzing during playing - so you get "Movie Mode"
sample s10e01
sample s10e02
so basically max is the problem?As far as the different offerings are concerned: Yes
there isnt any way to force platform (in this case max) to offer the 1080p always?I (and presumably SF) have no leverage to blackmail HBO Max or force them to do anything.
