hello, the first problem with eac3 sound track isn’t resolved with the last update…….. since 2 months
"Hello, I’m having a problem with Blu-ray/UHD Creator.
When I try to make a customized backup of a UHD disc with the EAC3 audio format, the encoding starts, but the movie doesn’t work at the end;
the image remains frozen and there’s no sound.
I have to convert the eac3 or e-ac3 audio format to AC3 for it to work properly. Is this normal ?
I think it worked fine before the August updates. Sincerely,"
