mkikuchi After copying DVD disk, try to open the copied files it does not work correctly at all. This phenomenon started from ver 13.0.4.7 and still the same on ver 13.0.4.8. Now I use DVD Fab 12 instead of 13. What happens on DVD Fab 13.0.4.7 and 13.0.4.8 for Mac.
Mona We will investigate the problem as soon as possible. In the meantime, you may try disabling Pathplayer in the DVDFab > Settings panel to load the DVD again.
