It’s a new problem because SF analyze the last epi
and this is not offered in German - so you can’t select German:
I’ve currently not found a way for individual Analyzis (or force a season) ..
.. so the only workaround I can offer is:
Analyze the serie and select you’re choice with english Audio
now “Add to Queue” and close SF
Go to %AppData%\DVDFab\StreamFab\taskdata
and open the file WOW in Notepad
find “eng-gb” and change to “deu-de”
(for multiple episodes use Search&Replace)
save the file, open SF and start the queue => that’s it
