shadowoflight91 I have the same problem as the ragazzibuoni. I select CBR but it downloads to CVBR. I have already uninstalled and reinstalled the program, deleting everything, but the problem persists. I don’t know if it depends on the country, I’m from Italy too
Germania shadowoflight91 I select CBR but it downloads to CVBR Wilson.Wang In prime video, not all of the videos have the CVBR and CBR. Please name the title and if it’s included in Prime I’ll test in Italy .. .. of course attaching your StreamFab.log is mostly helpful
shadowoflight91 The Dangers in My Heart for example For example, files that I previously downloaded in CBR now only download in CVBR. When I try to download the same file in CBR, the results are the same in CVBR and CBR.
Germania shadowoflight91 The Dangers in My Heart for example I get CBR in Italy without any problem - Compare the offers: CVBR CBR Result
shadowoflight91 So it’s my problem but other than deleting everything and reinstalling like I already did I don’t know what to do
Sebastian001 Did you have to reauthorize StreamFab during installation, or was it already authorized? If it was still authorized, it wasn’t completely removed.
Sebastian001 shadowoflight91 Did you also delete the folder under “App Data”? If you used Revo Uninstaller, for example, and followed all the instructions, I’m out of ideas.
RagazziBuoni TESTED ON A NEW PC, INSTALLED STREAMFAB 7.0, 1.1 FOR THE FIRST TIME AND ALWAYS DOWNLOADS IN CVBR WITH VERSION 7.0, 0.8 INSTEAD, EVERYTHING IS OK The Dangers in My Heart S01 E01
Stan001 RagazziBuoni Nice, let me check 7008, when I can, Amazon don’t work for me in 7011. Maybe I too then will have better luck in Amazon working,
Germania RagazziBuoni STREAMFAB 7,0,1,1 THE PROBLEM IS THAT THE TV SERIES ONLY DOWNLOAD IN H264 CVBR If you think my CBR DL (in post 28) was using 7008: btw: Please stop shouting (write everything in capital letters)
pjr57 This may or may not help but I have noticed for me if I select a resolution and bitrate instead of leaving it “Best Quality” it will then download H265. If I leave it as “best quality” it always gets H264 cbvr for me. New bug since 7011 , doesn’t happen with my 7008 install
mustangdmg Downloaded Vanished and The Night Manager with 7011. Checked for h265 but got h264 instead. Reverted to 7008 and I got them downloaded in h265. I’m in the US.
pjr57 mustangdmg that’s exactly what happens for me also , BUT if I select a resolution and bitrate as in the screenshot above it gets the H265 as selected
