Germania The log doesn’t even contain the URL that was accessed .. Looks like “Buffy the Vampire Slayer” to me .. .. is not included in D+ in the US => Hulu required But I can confirm that it don’t analyze for me in DE, CH or UK SF open only the Home screen
0xFeedBeef Germania yup, I clear the log prior to hitting the analyse button, but you guessed correctly… Also tried several others, same result
djhanje i try also some movies that are allready in my list to download from disney+ and get the message that there are no play link been found to download. i think Disney+ have changed the option to play from Disney+ and thereby to download the movie. i use no VPN.
simchris Anecdotally, just downloaded final last 2 eps of THE BEAUTY series. US, NoVPN, ad-free accounts, without any trouble.
TheCableGuy Version 7014 is completely broken for me; the analysis screen only appears briefly and then disappears again. Constant crashes. What the hell…
Germania TheCableGuy Version 7014 is completely broken for me 7014 was not broken, because D+ worked after release .. .. D+ change something (in Europe) after release and all SF versions are affected btw: My german D+ account works fine in US and without any crash
pino Germania I can confirm… VPN to the US works [7.0.1.4]. Slow, but it works. Looks like Disney is “optimizing” in Europe. Maybe this has something to do with the switch from HDR10. → Golem.de: Disney aktiviert HDR10 wieder für Premium-Abonnenten
Germania bmwbiker since Update of Streamfab to 7.0.1.4 It has nothing to do with SF update .. .. please read before create new topics - thx Germania 7014 was not broken, because D+ worked after release .. .. D+ change something (in Europe) after release and all SF versions are affected
beckmann.marcel It reflects exactly the same for me. VPN Poland and the Netherlands do not work, while the USA works.
Wilson.Wang I will ask the dev to check it ASAP. We got the same problem today when connecting to ITA via VPN. Wilson
rusche Hi everyone, nothing is working for me either. I only bought the Disney Plus module yesterday and nothing works. Really great impression of StreamFab…
0xFeedBeef rusche contrary to people’s desires, SF devs don’t have telepathic abilities, and can only fix things after they are broken by the vendors; be realistic about life! 🙄
MrGrackle rusche Hi everyone, nothing is working for me either. I only bought the Disney Plus module yesterday and nothing works. Really great impression of StreamFab… Providers change their code constantly. I hope you could be patient for a fix. Wilson acknowledged the issue to it seems very likely to be soon.
deadsearch I’m also having trouble with Disney Plus in Austria. Thanks for the quick reply and the confirmation that a fix is being worked on. 🙂
bmwbiker Hi, since 7.0.1.4. the analysis of movies do not finish so there is no download of movies at Disney. How to solve the problem or is it real Update-Error of Stramfab?
