Germania tomolo An update saw that there was a test version for disney and it works but not 7.0.1.5 Currently I can only confirm that analyzing starts with 7015 in Germany (unlike 7014 release) but it’s endless .. perhaps an SF server issue (slow today) 7014 test version works still fine
Wilson.Wang Germania It will not connect to StreamFab server when analyzing the metadata. Please turn on the auto analyzing and check it again.
Germania Wilson.Wang Please turn on the auto analyzing and check it again. It’s inconvenient to have to change the settings regularly. and that it analyzes endlessly even though Auto Analysis is disabled. Apart from that, an analysis of individual episodes is probably not possible. => unwanted step backward
tomolo It seems to work with automatic analysis, but the strange thing is that when I first tried 7015 2 hours ago it started as automatic analysis without it being on.
Wilson.Wang it started as automatic analysis without it being on. It’s the bug..😤 Impacted the analysis. And a new version 7016 will be released later and fix the bug.
Germania Wilson.Wang And a new version 7016 will be released later and fix the bug. I can confirm that with 7016 D+ can now analyze manually in Germany
mustangdmg 7016 works but it wouldn’t let me download either Atmos or ECAS for audio. I select either of them and it automatically downloads AAC instead.
Germania mustangdmg 7016 works but it wouldn’t let me download either Atmos or ECAS for audio. No problem detected (if offered) Please attach your StreamFab.log
Germania mustangdmg Please note that D+ Audio is sometimes incorrectly labelled by D+ Sometimes D+/SF offers Atmos, but it “only” contains normal EAC 5.1 EAC 2.0 is occasionally offered, but usually only contains AAC 128 That’s Mickey Mouse humor: D+ label EAC3 and offer AAC instead sample (source)
JM1 7016 still doesn’t work here in Germany, it keeps analyzing endlessly. With automatic option off, I can’t even start analyzing manually, the button stays grey. The only version that works so far is the 7014 test version.
Germania JM1 With automatic option off, I can’t even start analyzing manually In my post #12 you can see that this worked for me.
