Unless someone else went to buy it and try, I can only suggest the following:
Try again and download.
Maybe first try clearing the cache. temp folder, history in StreamFab? Then try downloading again.
Maybe if you use MP4, try MKV and vice versa?
Usually if it’s events they don’t always analyze. And then that means can’t be downloaded, so it did download something; maybe something is going wrong in processing?
