rick.richardson I have SF7.0.1.9 I can download from everyone except apple TV again. It says error analyzing check to see if I have access. I bring Apple TV up on Vivaldi browser and have no trouble bringing up the video I want. Just wondering if this is being fixed.
simchris Hi, itโs working for me, but getting random defective files (e.g., SILO, S1E7, S2E9+10, 4K DV/Atmos). Trying again one at a time. DID YOU CLEAR CACHE/TEMP FOLDER; THEN INSTALL LATEST VERSION AND RELOGIN TO APPLE?
rick.richardson I checked setting and found the Cache dir. Lots of system dirs, not touching. did find a subdir that had apple tv, further down, but it was empty. Signed out of Apple tv and then signed back in, same error. If you have a specific location that would be great.
Germania rick.richardson If you have a specific location that would be great. With SF >7007 the cache is in: %AppData%\DVDFab\StreamFab\rootCachePath So rename/delete cache and relogin
simchris TIP: change the location of the temp and cache folders in the SF settings. I use an external HDD for downloads and these locations to not kill my NVME drives early. So, my media drive is X, and I set both temp and cache to X:/SFAB and my downloads to X:/VIDEOS This makes it easy to just select all and delete everything in /SFAB periodically or with updated software versions. You could probably do this in your /user/mydocuments/sfab also if no external drive. See the settings in SF for locations. ๐
